Since the upgrade to 3.0.1.8, I get this error while updating de GEOIP databases:
Downloading file, please wait...
Error occurred while downloading GeoIP IPv4 data file: cURL error 7: Failed to connect to 2400:cb00:2048:1::6810:262f: Network is unreachable
Error occurred while downloading GeoIP IPv6 data file: cURL error 7: Failed to connect to 2400:cb00:2048:1::6810:262f: Network is unreachable
Download complete, unpacking files...
GeoIP IPv4 data file successfully unpacked
GeoIP IPv6 data file successfully unpacked
Process completed!
The files in the directory are 0 bytes:
drwxrwxr-x 2 root apache 4096 Feb 9 14:45 .
drwxr-xr-x 6 root root 4096 Feb 7 23:52 ..
-rw-r--r-- 1 apache apache 0 Feb 9 14:45 GeoIP.dat
-rw-r--r-- 1 apache apache 0 Feb 9 14:45 GeoIPv6.dat
-rw-r--r-- 1 root root 70 Jan 10 16:51 .gitignore
It looks like IP resolving is only to IPv6 address. I only have a IPv4 network connection.
GEOIP download problem sice update to 3.0.1.8
Re: GEOIP download problem sice update to 3.0.1.8
Odd. I am able to resolve to ipv4 addresses on 3.0.1.8.
What are getting when you resolve the following?
dig dev.maxmind.com
Same here...
Already tried to add the ip's to host file but this results in
Tried to manually download the file via curl with
curl -O http://geolite.maxmind.com/download/geo ... oIP.dat.gz
That works.
[admin@SMX2 ~]$ [b]dig dev.maxmind.com[/b]
; <<>> DiG 9.8.2rc1-RedHat-9.8.2-0.47.rc1.el6_8.4 <<>> dev.maxmind.com
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 54235
;; flags: qr rd ra; QUERY: 1, ANSWER: 2, AUTHORITY: 0, ADDITIONAL: 0
;; QUESTION SECTION:
;dev.maxmind.com. IN A
;; ANSWER SECTION:
dev.maxmind.com. 1152 IN CNAME maxminddev.wpengine.com.
maxminddev.wpengine.com. 119 IN A 104.197.225.108
;; Query time: 71 msec
;; SERVER: 127.0.0.1#53(127.0.0.1)
;; WHEN: Wed Mar 22 10:04:46 2017
;; MSG SIZE rcvd: 83
[admin@SMX2 ~]$ [b]dig geolite.maxmind.com[/b]
; <<>> DiG 9.8.2rc1-RedHat-9.8.2-0.47.rc1.el6_8.4 <<>> geolite.maxmind.com
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 24794
;; flags: qr rd ra; QUERY: 1, ANSWER: 3, AUTHORITY: 0, ADDITIONAL: 0
;geolite.maxmind.com. IN A
;; ANSWER SECTION:
geolite.maxmind.com. 15 IN CNAME geolite.maxmind.com.cdn.cloudflare.net.
geolite.maxmind.com.cdn.cloudflare.net. 299 IN A 104.16.38.47
geolite.maxmind.com.cdn.cloudflare.net. 299 IN A 104.16.37.47
;; Query time: 73 msec
;; WHEN: Wed Mar 22 10:05:49 2017
;; MSG SIZE rcvd: 121
Error occurred while downloading GeoIP IPv4 data file: cURL error 7: couldn't connect to host
Error occurred while downloading GeoIP IPv6 data file: cURL error 7: couldn't connect to host
Process completed!
That works.
And now they discontinued their free service.
on their website:
any ideas on what should be done, except deleting the GeoIP files?
on their website:
GeoLite Legacy databases were discontinued on January 2, 2019. Learn more
ideas? At least one: Search this forum
How? : viewtopic.php?f=5&t=2974
Result: viewtopic.php?f=13&t=3311
