Hi there,
I am trying to install EFA as a gateway for about 20 domains. Most of the mail goes to a server on the same network but some is forwarded to external servers. I am now using a Baruwa server for this which works great, but is getting old.
The gateway is on a local network and all traffic is natted to the server.
Greetings,
Roger
How do I configure EFA to be a gateway
Re: How do I configure EFA to be a gateway
Hi Roger,
See: https://wiki.efa-project.org/doku.php?id=setup_guide
You will need to add the domains, see: https://wiki.efa-project.org/doku.php?i ... il_domains
