New problem : No mail accepted by efa
mayrmart
Post by mayrmart »
Hi there,
New day new problems !
Efa reply all mails with
451 4.3.5 <xxx@domain.com>: Recipient address rejected: Server configuration problem
Nothing changed
Any ideas where to look ?
And there is no graylisting menu in console !
Server rebooted, greylisting disabled / enabled again
Martin
Re: New problem : No mail accepted by efa
Take a look in /etc/postfix/main.cf. Your problem is likely there. As for the greylisting, are you on 3.0.1.8? If so, there may be an issue. Perhaps I can help if you can provide some info. I'm investigating this issue.
