EFA Project never save any email
aadesh170
Post by aadesh170 »
I want to remove the email as soon as It is delivered. I tried to change q_days=0 in etc/MailScanner/defaults but it was not successful as some mails which were came in greylist weren't delivered everytime, If the email is not delivered, it should stay in the mail filter so it can be released
Any help will be greatly appreciated.
Thank you
Re: EFA Project never save any email
Firstly, you will want to disable storing non-spam.
In EFA-Configure 8) Spam Settings 1) Non Spam Settings
Secondly, you need to decide whether or not to use greylisting. Greylisting, by design, works directly with the postfix MTA. Emails greylisted that never clear the greylist will never be logged or quarantined, because they never will be accepted by the MTA.
aadesh170
Post by aadesh170 »
Okay Thankyou very much. I will try this solution :)
