signature
Ravikant144
signature
Any One can suggest me how can i remove Signature
This message has been scanned for viruses and dangerous content by
E.F.A. Project, and is believed to be clean.
Re: signature
You can disable the signature using EFA-Configure.
Re: signature
(for completeness, from
viewtopic.php?f=14&t=684&p=1871&hilit=d ... ture#p1871 )
Use efa-configure --> Spam Settings --> Non-Spam Settings
You can disable signatures here.
Re: signature
looks like this is a complete ON/OFF settings, I am however looking to only disable adding signatures to OUTGOING emails.
I looked around and it seems this rule could be the solution: sig.html.rules + sig.txt.rules
this is what the first one looked like originally:
so I tried modifying it:
but a MailScanner --lint warned me:
Any ideas how to do this?
To: default /etc/MailScanner/reports/en/inline.sig.out.html
To: *@mydomain1.de /etc/MailScanner/reports/en/inline.sig.in.html
To: *@mydomain2.de /etc/MailScanner/reports/en/inline.sig.in.html
Could not read file no at /usr/share/MailScanner/perl/MailScanner/Config.pm line 2856
Syntax error in line 4 of ruleset file /etc/MailScanner/rules/sig.html.rules at /usr/share/MailScanner/perl/MailScanner/Config.pm line 2803
Re: signature
Is this possible? Anyone? I suspect the outgoing signature messes up my DKIM signing :-/
Re: signature
Try this, drop the first line:
To: *@mydomain2.de /etc/MailScanner/reports/en/inline.sig.in.htmlRe: signature
Didn't seem to work out in the sense that mails still get signed going in and out so now I am determined to stop signing them altogether in order to sort out my DKIM headers.
I went to efa-configure --> Spam Settings --> Non-Spam Settings and disabled signing non-spam emails.
Inside /etc/MailScanner/MailScanner.conf
cat /etc/MailScanner/rules/sig.text.rules
/etc/MailScanner/reports/en/inline.sig.out.txt has content
cat /etc/MailScanner/rules/sig.html.rules
/etc/MailScanner/reports/en/inline.sig.out.html has content
Inline HTML Signature = %rules-dir%/sig.html.rules
Inline Text Signature = %rules-dir%/sig.text.rules
Sign Messages Already Processed = no
Sign Clean Messages = No
To: default /etc/MailScanner/reports/en/inline.sig.out.txt
To: *@mydomain2.de /etc/MailScanner/reports/en/inline.sig.in.txt
To: *@prehcm.de /etc/MailScanner/reports/en/inline.sig.in.html
To: *@prehcmservices.de /etc/MailScanner/reports/en/inline.sig.in.html
Re: signature
I would be curious if this might work:
To: default no
Re: signature
sorry to say but deleting the "default" line then /etc/init.MaiLScanner reload doesn't change anything, I still get footers added for outgoing emails.
Changing the default to no gives the same syntax error as I first reported.
Re: signature
What if instead of no you put /dev/null ?
Re: signature
OK, this is officially driving me insane. I can't test /dev/null "live" I might give it a try over the weekend.
BUT I just set this up in MailScanner.conf
RESTARTED MailScanner and guess what? I still get a footer added to my outgoing messages:
Sign Clean Messages = NoI really just want to disable any and all footers, in and outgoing. Any advice on how to do that?--
our in-house Email Filtering Appliance, and is believed to be clean.
Re: signature
Look at Spam Actions and Non Spam Actions and remove the "custom" entry for each.
Re: signature
ah, thanks for clarifying.
- is that all that the custom action does?
- are there any drawbacks to simply doing this inside the conf file vs. the EFA interface?
Re: signature
in effect, when the E.F.A puts the footer, the dkim signature gets invalid.
I'm trying to disable the signature only on the outgoing clean mails, but it doesn't work, the only way I found is disable the clean message signature, but this is for incoming and outgoing emails.
