Hi.
Every morning a cron job is started at 05:01.
It's a standard job that is part of EFA and not any modification is done to it.
At that time and every hour after that there is CROND process running.
Every morning I kill a database connection for a command (se below) and after that all is well.
"DELETE i.*, m.* FROM mtalog AS m LEFT OUTER JOIN mtalog_ids AS i ON i.smtp_id = m.msg_id WHERE m.timestamp < (NOW() - INTERVAL 1 DAY)"
I have reinstalled EFA and the problem is back again.
Anybody that has experienced anything like this or why it happens?
/Lennart.
						Cron job hanging
Re: Cron job hanging
If anyone else is having issues, please chime in.  I wonder if this is similar to the database lock issue another user was experiencing.
