initial config
scanner
initial config
Post by scanner »
HI, for the life of me I cant find this username and password, in the wiki it shows, root/EfaPr0j3ct. does that mean user = root and password = /EfaPr0j3ct. if it does it does not work, searching this forum came up with two others who instead of posting their finding they just posted nevermind, not helpful.
wilbourne
Re: initial config
Post by wilbourne »
scanner wrote:HI, for the life of me I cant find this username and password, in the wiki it shows, root/EfaPr0j3ct. does that mean user = root and password = /EfaPr0j3ct. if it does it does not work, searching this forum came up with two others who instead of posting their finding they just posted nevermind, not helpful.
user: root
password: EfaPr0j3ct
scanner
Re: initial config
Post by scanner »
found it. on the interweb.
username = root
password = EfaPr0j3ct
scanner
Re: initial config
Post by scanner »
user: root
