Can I change the admin login username
gcstech
Post by gcstech »
I ran into an issue where I need to change the admin username. Not just the password but the username also. Is it possible to create a different admin user? I did not find an answer in the forums but my search skills may have been weak today. Thank you in advance.
Phil
Re: Can I change the admin login username
On the console or the webgui, or both?
