Upgrading hyperv image to newest version not working
shareonline
Post by shareonline »
Hi all, i just finished setting up EFA in front of my Exchange, as i wanted a replacement for xeams.
So far it is working okay and mail gets delivered. But..
I cannot get LDAP to Work, when i try to log in with either UPN/Mail/Samaccountname i just get a http 500 error..
Furthermore, i cannot update the server to the new version 3.0.1.5. I'm on the 3.0.0.9 build so a Little far behind:)
When i try to update, it goes to Work, backs up, downloads etc. I can see that it first tries to update to 3.0.1.0 but then fails with this:
error: Packadge util-linux-ng-2.17.2-12.24.e16.x86_64 (updates)
requires: kernel-2.6.32-642
Installed: kernel-2.6.32-573.e16.x86_64 (@anaconda-CentOS-201508042137.x86_64/6.7)
update to version 3.0.1.0 FAILED
Can anybody help me? I really wanna get this going, but wont configure to much if i have to do it all over Again:) Furthermore i cannot find a hyperv image of the new 3.0.1.5??
Re: Upgrading hyperv image to newest version not working
Did you try rebooting into the new kernel?
shareonline
shawniverson wrote:Did you try rebooting into the new kernel?
Hmm no im really not a linux guy so no idea how to do that? I thought it came preloaded with only one kernel?
shareonline
I just tried to import the hyperv image to a new vm, quickly walked through the configuration, and it has the same problem. So to me it seems like the 3.0.0.9 hyperv image has a broken update function?
But if somebody could please give me a shell command or guide to booting into the other kernel it would really help me :think:
shareonline
I tried the following yum install kernel-2.6.32-642.6.2.el6.centos.plus.x86_64.rpm, but it tells me no packadge available..
when i do yum check-update | grep kernel
it gives me info about 2.0.8-40.el6.centos.. Please help i really wanna update to newest version :)
Morotalizer
Post by Morotalizer »
same issue/error for me.
Seems something missed when creating the hyper-v appliance
shareonline
Morotalizer wrote:same issue/error for me.
Glad I'm not the only one :) hoping for a fix, and in the meantime it really is a good spam filter. Pretty impressed so far :)
Morotalizer
i'm linux noob...but i managed to update the kernel (its updating the efa right now so i dont know if this is supported, but it seems to work)
Googled this:
https://www.centos.org/forums/viewtopic.php?t=17716
And found that kernel was excluded from update.. so i..
Edit
/etc/yum.conf
exclude=kernel* mysql* postfix* mailscanner* clamav* clamd* open-vm-tools* perl-Net-DNS
To
exclude=mysql* postfix* mailscanner* clamav* clamd* open-vm-tools* perl-Net-DNS
The run
yum update kernel
Then i was able to run update... but as i say i'm noob at linux and haven't verified that everything is working after this. :-)
Update is supposed to update the kernel first. Interesting it did not do that for you :think:
shareonline
Morotalizer wrote:i'm linux noob...but i managed to update the kernel (its updating the efa right now so i dont know if this is supported, but it seems to work)
Googled this:
Edit
/etc/yum.conf
To
The run
yum update kernel
Wow nice find! Will test this instantly :) will report back with findings..
shareonline
It works great! I\m now on latest version and so far everything seems to work great! Thx for the help guys!
Morotalizer
maybe change back the yumf.conf after update?
shareonline
Morotalizer wrote:maybe change back the yumf.conf after update?
Yup did that just in case. And if it fails Again we know what to do.. :whistle:
