CLAMAV Detected duplicate database
c0mputerking
Getting errors after updating to 3.0.1.5 granted i have not updated for awhile so not sure which update may have caused this or even if it was an update, might have just been that look since i seen a reboot on the console ... NOTE my apologies for the bad photo but i cannot find this error in any of the logs
- 20161018_125928.png (834.56 KiB) Viewed 6250 times
c0mputerking
Re: CLAMAV Detected duplicate database
I did a fresh install to a fresh VM using the ISO install method not the VMware as i am using proxmox, but still get the same error not sure how bad this is? how can i fix this? or should i ignore it?
- efa-2.png (48.43 KiB) Viewed 6207 times
Benign, you can safely ignore.
