Unable to parse the OVF file
sem
Post by sem »
Just tried to get our sysadmin to import the OVF into Vsphere 4.1. The error Unable to parse the OVF file occurs and it won't import.
darky83
Site Admin
Re: Unable to parse the OVF file
Post by darky83 »
The hardware version from the OVF file is 8
http://kb.vmware.com/selfservice/micros ... Id=1003746
This means only the following versions are supported:
- ESXi 5.x
- Fusion 4.x
- Workstation 8.x
- Player 4.x
Your sysadmin can use vmware converter to change the OVF file to the older VMware 4.1 format.
I will keep this in mind and will create the 0.3 version with Hardware version 7 so older versions of vmware are still supported.
d.
sem
Post by sem »
Thanks man! I'll let him know about converting. Do you have a roadmap for 0.3?
darky83
Site Admin
Post by darky83 »
Not really a roadmap but I expect to have 0.3 available within a month or so.
mostly small bugfixes and stability issies I found in 0.2 no major new features yet :)
d.
sem
Post by sem »
Do you think 0.2 is good enough for a production environment? BTW, did the steps in the looping post make sense?
darky83
Site Admin
Post by darky83 »
I am currently running it in production, and I know some others that also use it in production so it seems stable enough :)
I would recommend having some linux & mailscanner knowledge/experience before using it in a production environment as it is a new project I can't guarantee a flawless product.
(My current most busy system processes about 15000 messages a day and still havn' t found any critical bugs)
Your post made sense, I will take a look at it later on to see if i can reproduce and try to fix it.
d.
sem
Post by sem »
Thanks man!
Linux knowledge no problemo but mailscanner is new (to me). I shall read up some more. Ideally, we'd have a web frontended mail scanning appliance that generally doesn't need any messing around with the console as my time there is limited so it would be day-to-day administrated by people without experience. I probably made things worse taking the Postfix fixes learned from Zimbra over to EFA - I just didn't want to be in the postion of loosing any mail because the Exchange box wasn't playing ball.
sem
bbrendon
Post by bbrendon »
I just tried to install this into our main esx environment which is 4.x. I was on a 4.0.0 server and I got this error:
Line 27: Unsupported hardware family 'vmx-08'.
I tried to change the line manually and it said the file was invalid. I'm thinking the ovf file is signed? Not sure.
We have a dev environment with esx 5 which I will install on for now.
cacchip
Post by cacchip »
I believe that you need ESX 5 for VMX-8 hardware.
darky83
Site Admin
Post by darky83 »
I added a note to the download page that the current VMware build requires ESX 5 or higher.
A next build will be done using a lower hardware number so ESX 4 is also supported.
d.
