Need help with blacklist issue (how to blacklist from non-existing 'from' email)
sizenet
Post by sizenet »
First of all, even tho I am a new EFA user here... I must admit EFA is amazing. The reason I started to use EFA is obviously spam related... Let me summarize the problem and maybe you guys can point me to the right direction.
I started to receive lots of emails from postmaster@domain.com (always a different domain name) with the subject: Delivery report. To stop this annoying spam, this is what I did:
1- After installing and configuring EFA, I forwarded the MX record of the domain that is being spammed to the EFA.
2- As expected, all the emails are being delivered to EFA first, and if they are not spam they come to my inbox.
3- However, some of these postmaster@domainnamehere.com still make their way to the inbox directly....
For instance, I attached 2 screenshots to show how bad it is and what I can do to resolve it. Please see the attached(s).
How can I block the emails when the 'from' is empty (as you see in the screenshot)?
Second attached image also shows that empty 'from' email address that is why I can not add to the block list?
I checked the forums and found how to block the emails based on the subject line: viewtopic.php?t=597 -- tried the last post (solution) unfortunately, did not work.
I would appreciate if you guys can tell me how to properly block emails based on their email address - and if email address is not present - based on their subject...
Thank you for your help!
Re: Need help with blacklist issue (how to blacklist from non-existing 'from' email)
Post by nicola.piazzi »
are you sure that your system is not an open relay ?
Or it was an open relay previously and now you are receiving old NDR ?
if you send me your email address i can make a check of your config
sizenet
Post by sizenet »
Hi Nicola,
Thank you for the quick response. I am sure the system is not an open relay.
I even checked with http://www.mailradar.com/openrelay/ to make sure.
I am sending you a PM.
Please check.
Thank you!!!
ovizii
Post by ovizii »
You could give this a try: http://www.backscatterer.org/?target=usage
I am using the safe method with postfix and my check_backscatterer looks like this:
<>              reject_rbl_client       ips.backscatterer.org
postmaster      reject_rbl_client       ips.backscatterer.org
MAILER-DAEMON   reject_rbl_client       ips.backscatterer.org
that should cut down at list a bit of that SPAM.
I also have this problem but those are basically backscatter if I am not mistaken. For the domains I host, I have setup SPF+DKIM+dmarc so there is absolutely no reason to send me this type of NDRs especially since most of the ones I receive are for non-existing recipients on my side, hence my guessing its backscatter SPAM.
