Upgrade from 3.0.0.7
Sillen42
Post by Sillen42 »
Hi.
i'm having problem with upgrading a customers EFA from 3.0.0.7.
When I run EFA-Update I get the following error:
The version file download does not seem to be valid.
Any ideas why and if can be solved?
/Lennart.
Sillen42
Re: Upgrade from 3.0.0.7
Post by Sillen42 »
Corrected Proxy settings solved the problem.
/Lennart.
