Recent Message tab not show any email
mpndang
Post by mpndang »
I think I saw one of the post asking about this but I couldn't find it even in search.
When it was at 3.0.0.9 and 3.0.1.1, all incoming mails shown but after it's updated to 3.0.1.5, the Recent Message tab no longer show any emails. Does anyone know how to fix it?
Thank you
mpndang
Re: Recent Message tab not show any email
Post by mpndang »
I got it fixed but not the code. I think there were incorrect path in SQLBlackWhiteLiet.pm and MailWatch.pm when doing the update to version 3.0.1.5. What I did is I installed the version 3.0.1.5 below, then copy those 2 files and transfer to my update 3.0.1.5( was updated from 3.0.0.9) version. It works after that. If you pay attention to boot up the linux, you would see error of MailScanner Starting .... "unable to initialize database......" This ist he reason Recent Messages do not show any. You can capture the screen then look to see which files are failed, then try to fix the path if you know how. I don't so I installed the version below then transfer the files over. :P
viewtopic.php?t=1859
