I made the mistake of using the same name in EFA as my admin user as a name on my active directory so when I login with LDAP enable or true I can only see my own emails. When set to false I see all emails. I thought I saw an answer to this but I can't find it again. What is the best way to change the admin username or add another admin user with a different name? Just a suggestion is there a way during install that a message says something like "If you are going to use LDAP make sure to use a unique admin username.
Thank you for the great program and all of your efforts!
Can't see all users in Mailwatch after Active intergation
Re: Can't see all users in Mailwatch after Active intergation
It's okay. I just reinstalled the program and changed the admin name to something unique.
