Hola,
Can you please upgrade postfix to 3.1.3? I think I have hit an ldap lookup problem in 3.0.4. My system is very sluggish, I think due to the current postfix version deployed in EFA.
Or can you explain how to upgrade to 3.1.3? The efa repo only has 3.0.4 ...
Ronald
postfix upgrade
Re: postfix upgrade
3.1.3, you say?
Cool, I'll get an rpm ready
Wanna help me test it out?
Re: postfix upgrade
sorry about my lame reply!
If you need some help, sure I can help. My problem tough was unrelated after all. I used a heavy body check from postfix whish caused the sluggyness. Things are up to speed now.
However, if you need some help in testing things, just drop me a line, I ll see what I can do.
Grtz
Grtz
