I am going to my backend => Tools/Links => View Munin Statistics and I get: This site can’t be reached
Munin is running. I am running an installation based upon your vmware appliance. EFA 3.0.0.1
						The munin link doesn't work
Re: The munin link doesn't work
Is the link https://[SERVERURL]/munin/ ?
just figured out, it works with HTTPS but not with HTTP
just to clarify:
you have https disabled (11)) and the link is http://[SERVERURL]/munin/ ?
That was correct. Once I enabled https it started working.DaN wrote:just to clarify:
admin password not work to log in to munin
what user can log on ?
The password is randomized. You can access munin via MailWatch if the following is true:yahav02 wrote:admin password not work to log in to munin
1) HTTPS is enabled (to allow password to be passed securely)
2) DNS record for your EFA is properly defined and matches the host
how can i know what is my root password?
thenks
munin work good i fix dns of the meshine
the password reset from webmin
thenks !!!!
thenks !!!!
