No Quarantine Report since Update
Hybrid1980
Post by Hybrid1980 »
Hallo,
first a BIG THX for the Project :)
I have a little problem,
after the Update to 3.1.0.3 from 3.1.0.1 the Users don´t become a Report
when i execute the /usr/local/bin/mailwatch/tools/Cron_jobs/quarantine_report.php
i become the error
=== Generating report for XXXXX type=A
 ==== huflejt has empty e-mail recipient address, skipping...
 === Generating report for XXXXXxX@XXXX.XX type=U
 ==== Recipient e-mail address is XXXXXxX@XXXX.XX
 ==== Building list for XXXXXxX@XXXX.XX
<B>Error executing query: </B><BR><BR>1054: Unknown column 'isaspam' in 'where clause'<BR><BR><B>SQL:</B><BR><PRE>
SELECT DISTINCT
a.id AS id,
DATE_FORMAT(timestamp,'%d/%m/%y <br/>%H:%i:%s') AS datetime,
a.to_address AS to_address,
a.from_address AS from_address,
a.subject AS subject,
CASE
 WHEN a.virusinfected>0 THEN 'Virus'
 WHEN a.nameinfected>0 THEN 'Bad Content'
 WHEN a.otherinfected>0 THEN 'Infected'
 WHEN a.ishighspam>0 THEN 'Spam'
 WHEN a.issaspam>0 THEN 'Spam'
 WHEN a.isrblspam>0 THEN 'Spam'
 WHEN a.spamblacklisted>0 THEN 'Blacklisted'
 WHEN a.isspam THEN 'Spam'
 WHEN a.ismcp>0 THEN 'Policy'
 WHEN a.ishighmcp>0 THEN 'Policy'
 WHEN a.issamcp>0 THEN 'Policy'
 WHEN a.mcpblacklisted>0 THEN 'Policy'
 WHEN a.isspam>0 THEN 'Spam'
 ELSE 'UNKNOWN'
END AS reason
FROM
 maillog a
WHERE
 a.quarantined = 1
AND
 ((to_address='XXXXX@XXXXXXXX) OR (to_domain='XXXXX@XXXX.de'))
AND
 a.date >= DATE_SUB(CURRENT_DATE(), INTERVAL 1 DAY)
    AND
    isspam>0
        AND
        virusinfected>0
        OR
        nameinfected>0
        OR
        otherinfected>0
        OR
        ishighspam>0
        OR
        isaspam>0
        OR
        isrblspam>0
        OR
        spamblacklisted>0
        OR
        isspam>0
        OR
        ismcp>0
        OR
        ishighmcp>0
        OR
        issamcp>0
        OR
        ismcpblacklisted>0
        OR
        isspam>0
ORDER BY a.date DESC, a.time DESC</PRE>[root@spam ~]#
Anyone a idea?
Sorry for my bad English :)
Big thanx
Daniel
Hybrid1980
Re: No Quarantine Report since Update
Ok, i see the problem is already known, thanks
Greets from Germany
Daniel
ldecoker
Post by ldecoker »
Hello!
I got the same problem. Can you add the bug report link for this bug?
thx!
ldecoker
Post by ldecoker »
Thx. I updated it and it's working .. but for users for which the override email field is empty, I received the following message: "has empty e-mail recipient address, skipping..."
From my understanding, the override recipient field is optional and if empty, the username will be used, right?
SharazJek
Post by SharazJek »
im on 3.1.0.4, and same issue.
[root@dlp-upemx01 ~]# php /usr/local/bin/mailwatch/tools/Cron_jobs/quarantine_report.php
=== Generating report for jhorne@yay.org type=R
==== jhorne@yay.org has empty e-mail recipient address, skipping...
Interesting, I'm not seeing this. How is this user set up in MailWatch?
dbrunt
Post by dbrunt »
If the username is simply "user", you have to complete the overriding email field. If the username is user@somedomain.com then an overriding email address is not required unless the user type is Administrator or Domain Administrator, in which case you have to have an overriding email address despite what the GUI says.
See viewtopic.php?f=13&t=1873
I've not checked this in 3.0.1.5 yet but it was still an issue in 3.0.1.1.
