Disable {Spam not delivered} notifications
lavazza
Post by lavazza »
where is the setting located (if any) to disable the "{Spam not delivered}" notification on one specific mailbox?
Re: Disable {Spam not delivered} notifications
For a single user...
I'll take a look. I think it can be done in MailScanner using a ruleset... :think:
dbrunt
Post by dbrunt »
Can this be done?
cdburgess75
Post by cdburgess75 »
It would be nice to enable or disable for certain users.
Answer: yes
You have to create a ruleset and set Spam Actions = /path/to/ruleset.rule
The "ruleset.rule" would contain something like this (replace <tab> with real tabs)
To:<tab>someone@example.com<tab>store
FromOrTo:<tab>default<tab>store notify
dbrunt
Post by dbrunt »
:clap:
Question,
Is the correct syntax in the rule "store,notify" or "store notify"?
MailScanner.conf appears to be using a space separator between action keywords...
Corrected...got in a hurry :whistle:
cdburgess75
This works great, thank you!
dbrunt
Post by dbrunt »
What about wildcarding?
To:<tab>*@example.com<tab>store
To:<tab>@example.com<tab>store
To:<tab>example.com<tab>store
ovizii
Post by ovizii »
Didn't the latest version 3.0.1.4 basically replace the {Spam not delivered} notifications or do we now have both, these and the daily quarantine reports available?
dbrunt
Post by dbrunt »
I'm not aware of that.
EFA has always had {Spam not delivered} notifications (global option yes/no) and Daily Quarantine report (user option yes/no).
Both functionalities should be there.
dbrunt
Post by dbrunt »
Shawn,
Any idea on my wildcard question?
I think it works if you leave off the "*@"
dbrunt
Post by dbrunt »
Just to be clear for others, here is our implementation:
In /etc/MailScanner/conf.d create:
spam.actions.conf
Spam Actions = %rules-dir%/spam.actions.rules
In /etc/MailScanner/rules create:
spam.actions.rules
To:     user@mydomain.com        store
FromOrTo:       default store custom(spam)
(Use tabs between fields)
