woundride
Posts: 52 Joined: 19 Mar 2015 14:34
Post
by woundride » 12 Sep 2016 17:00
After I've updated my EFA system 3.0.1.1 to 3.0.1.4, I've a bug, all my incomming mails are rejected with status "Others" :
I restored a snapshot
Have you an idea ?
Thank you.
Best regards,
Charles
Posts: 1585 Joined: 18 Mar 2015 09:16
Post
by pdwalker » 12 Sep 2016 18:28
Hi Charles,
I think I'd need to see the full headers of one of those messages (click on the #) to get a better idea of why.
Posts: 3783 Joined: 13 Jan 2014 23:30
Post
by shawniverson » 12 Sep 2016 21:18
Some thoughts...
Rebooted after updating?
Any errors from the update itself?
Does the lint tests reveal any problems?
Are you using another A/V scanner and need to add it to the new mtagroup?
woundride
Post
by woundride » 13 Sep 2016 11:01
Thank you for your help
With you, I've found the issue.
Reading the new MailScanner configuration file, I saw that F-Prot was not proposed in the AV list
By removing F-Prot it's solved.
For F-Prot Users :
F-Prot is no longer compatible
Still Thanks for your help !
Best regards,
Charles
toddh
Posts: 69 Joined: 16 Feb 2015 18:52
Post
by toddh » 14 Sep 2016 02:57
Any idea when, or if, F-Prot will be functional in EFA?
We use it as well in conjuction with Clam.
Thanks for all the great work!
toddh
Post
by toddh » 14 Sep 2016 14:10
Disregard, thought we were using F-Prot but its actually Sophos on EFA.
Still thanks for all the Great Work!
woundride
Post
by woundride » 15 Sep 2016 09:44
I guess that's it ended for F-Prot
In the new MailScanner's configuration file (/etc/MailScanner/MailScanner.conf), F-Prot is no longer in the list of compatible antivirus (even if it is still in one example).
