EFA spam notification
mreinder
Post by mreinder »
First my compliments for the great work you all are doing!
A strange thing that I see sometimes is that some spam messages between spam (5) and high spam (8) is not deliverd to users.
Like the one below:
Sep  6 10:01:54 efa MailScanner[2331]: Message 3245B10001F.A4C98 from 85.194.241.179 (608030033002--90@trmaildat.com) to paswerk.nl is spam, SpamAssassin (not cached, score=6.898, required 4, DCC_CHECK 1.10, HEADER_FROM_DIFFERENT_DOMAINS 0.00, HTML_MESSAGE 0.00, MIME_HTML_MOSTLY 0.00, MPART_ALT_DIFF 0.72, RCVD_IN_MSPIKE_H3 -0.01, RCVD_IN_MSPIKE_WL -0.01, RP_MATCHES_RCVD -1.06, SPF_PASS -0.00, URIBL_ABUSE_SURBL 1.95, URIBL_BLACK 1.70, URIBL_DBL_PHISH 2.50)
Sep  6 10:01:54 efa MailScanner[2331]: Spam Checks: Found 1 spam messages
Sep  6 10:01:54 efa MailScanner[2331]: Skipping sender of precedence bulk
Sep  6 10:01:54 efa MailScanner[2331]: Spam Actions: message 3245B10001F.A4C98 actions are store,custom
Sep  6 10:01:54 efa MailScanner[2331]: Deleted 1 messages from processing-database
Sep  6 10:01:54 efa MailScanner[2331]: Logging message 3245B10001F.A4C98 to SQL
I think that I see what there is is common in al the messages : URIBL_DBL_PHISH 2.50
Is it correct that messages with this spam listing is ignored?
I'm running on the latest efa version 3.0.1.3
ovizii
Re: EFA spam notification
Post by ovizii »
afaik that is normal that messages between spam (5) and high spam (8) are not delivered.
in older EFa versions those recipients would get a {Spam not delivered} notifications and they could chose to deliver the message, in newer EFa versions they will only see it in the daily quarantine report and can release those emails from there.
Try toggling the spam notifications in EFA-Configure and see if that resolves the issue.
ckruijntjens
Post by ckruijntjens »
Hi Everyone,
did yougot this working? I toggled it off and on however when i recieve a spam message efa wont notify me by mail?
What do you see in /etc/MailScanner/MailScanner.conf on this line?
Spam Actions = ?
