Message size exceeds size limit 10485760
maik
Post by maik »
I've been beating my head against this for the past day or so. Any incoming emails over 10M in size get rejected with a bounce message, reportedly from Postfix, stating the size exceeds that 10MB limit. I have no idea what setting is affecting this and it's really frustrating. Postfix appears to be set to 512000000, though that clearly isn't the case, and the Mailscanner configuration (under the rules folder) lists 0 as the default (which it says is unlimited) for FromOrTo. I explicitly set 50MB and it doesn't appear to make any difference. What am I missing?
darky83
Site Admin
Re: Message size exceeds size limit 10485760
Post by darky83 »
by default messages less than 50Mb should be accepted.
Just tested this on multiple EFA 0.3 machines to be sure but all just accept.
Could you maybe post the exact bounce message & the logging section of /var/log/mail.log?
See below, this is on a default efa0.3 installation when sending a 20MB message from gmail:
Sep  5 03:14:55 EFA03 postfix/cleanup[9760]: B0A2118005B: hold: header Received: from mail-wg0-f52.google.com (mail-wg0-f52.google.com [74.125.82.52])??by EFA03.efaproject.org (Postfix) with ESMTPS id B0A2118005B??for <test@efa-project.org>; Thu,  5 Sep 2013 03:14:55 -0400 (EDT from mail-wg0-f52.google.com[74.125.82.52]; from=<test@efaproject.org> to=<test@efa-project.org> proto=ESMTP helo=<mail-wg0-f52.google.com>
Sep  5 03:14:55 EFA03 postfix/cleanup[9760]: B0A2118005B: message-id=<CAEO7NJbnkrub3bDZXVJqKmpbwpAZHN2GLav9uE=xhmvbLUwN9Q@mail.gmail.com>
Sep  5 03:14:58 EFA03 postfix/smtpd[9756]: disconnect from mail-wg0-f52.google.com[74.125.82.52]
Sep  5 03:14:58 EFA03 MailScanner[7305]: New Batch: Scanning 1 messages, 28700990 bytes
Sep  5 03:15:02 EFA03 MailScanner[7305]: Virus and Content Scanning: Starting
Sep  5 03:15:06 EFA03 MailScanner[7305]: Spam Checks: Starting
Sep  5 03:15:06 EFA03 MailScanner[7305]: Expired 2 records from the SpamAssassin cache
Sep  5 03:15:06 EFA03 MailScanner[7305]: Baruwa: whitelist refresh time reached
Sep  5 03:15:06 EFA03 MailScanner[7305]: Baruwa: Starting whitelists
Sep  5 03:15:06 EFA03 MailScanner[7305]: Baruwa: Read 106 whitelist items
Sep  5 03:15:06 EFA03 MailScanner[7305]: Baruwa: Ip blocks whitelisted:
Sep  5 03:15:06 EFA03 MailScanner[7305]: Baruwa: blacklist refresh time reached
Sep  5 03:15:06 EFA03 MailScanner[7305]: Baruwa: Starting blacklists
Sep  5 03:15:06 EFA03 MailScanner[7305]: Baruwa: Read 0 blacklist items
Sep  5 03:15:06 EFA03 MailScanner[7305]: Baruwa: Ip blocks blacklisted:
Sep  5 03:15:06 EFA03 MailScanner[7305]: Message B0A2118005B.AA89A from 74.125.82.52 (test@efaproject.org) to efa-project.org is too big for spam checks (28700990 > 200000 bytes)
Sep  5 03:15:14 EFA03 MailScanner[7305]: Requeue: B0A2118005B.AA89A to B959518006A
Sep  5 03:15:14 EFA03 postfix/qmgr[5160]: B959518006A: from=<test@efaproject.org>, size=28700309, nrcpt=1 (queue active)
Sep  5 03:15:14 EFA03 MailScanner[7305]: Uninfected: Delivered 1 messages
Sep  5 03:15:14 EFA03 MailScanner[7305]: Deleted 1 messages from processing-database
Sep  5 03:15:14 EFA03 MailScanner[7305]: Baruwa: Logging message B0A2118005B.AA89A to SQL
Sep  5 03:15:14 EFA03 MailScanner[7307]: Baruwa: B0A2118005B.AA89A: Logged to SQL
Sep  5 03:15:14 EFA03 postfix/smtp[9780]: B959518006A: to=<test@efa-project.org>, relay=172.19.234.20[172.19.234.20]:25, delay=19, delays=19/0/0.02/0.4, dsn=2.0.0, status=sent (250 2.0.0 Ok: queued as 7B065DF98D)
Sep  5 03:15:14 EFA03 postfix/qmgr[5160]: B959518006A: removed
It won't do spam checking because the mail is to big but it accepts the mail for delivery.
maik
Post by maik »
Here's the bounce message.
This is the mail system at host efa.example.com.
I'm sorry to have to inform you that your message could not
be delivered to one or more recipients. It's attached below.
For further assistance, please send mail to postmaster.
If you do so, please include this problem report. You can
delete your own text from the attached returned message.
                   The mail system
<administrator@example.com>: message size 24229586 exceeds size limit
    10485760 of server mail.example.com[10.1.2.3]
Final-Recipient: rfc822; administrator@example.com
Original-Recipient: rfc822;administrator@example.com
Action: failed
Status: 5.3.4
Diagnostic-Code: X-Postfix; message size 24229586 exceeds size limit 10485760
And here is a snippet from /var/log/mail.log.
Sep  4 07:27:32 lpul-efa MailScanner[1733]: Message CC2442C00C1.A3D94 from 209.85.219.52 (user@mydomain.net) to example.com is too big for spam checks (24230301 > 200000 bytes)
Sep  4 07:27:40 lpul-efa MailScanner[1733]: Requeue: CC2442C00C1.A3D94 to 862C82C00C5
Sep  4 07:27:40 lpul-efa postfix/qmgr[1965]: 862C82C00C5: from=<user@mydomain.net>, size=24229586, nrcpt=1 (queue active)
Sep  4 07:27:40 lpul-efa MailScanner[1733]: Uninfected: Delivered 1 messages
Sep  4 07:27:40 lpul-efa postfix/smtp[2685]: 862C82C00C5: to=<administrator@example.com>, relay=mail.example.com[10.1.2.3]:25, delay=562, delays=562/0.01/0.01/0, dsn=5.3.4, status=bounced (message size 24229586 exceeds size limit 10485760 of server mail.cacwhitman.local[10.1.2.3])
Sep  4 07:27:40 lpul-efa postfix/cleanup[2586]: D3BCF2C00C6: message-id=<20130904052740.D3BCF2C00C6@efa.example.com>
Sep  4 07:27:40 lpul-efa MailScanner[1733]: Deleted 1 messages from processing-database
Sep  4 07:27:40 lpul-efa MailScanner[1733]: Baruwa: Logging message CC2442C00C1.A3D94 to SQL
Sep  4 07:27:40 lpul-efa postfix/qmgr[1965]: D3BCF2C00C6: from=<>, size=4066, nrcpt=1 (queue active)
Sep  4 07:27:40 lpul-efa postfix/bounce[2686]: 862C82C00C5: sender non-delivery notification: D3BCF2C00C6
Sep  4 07:27:40 lpul-efa postfix/qmgr[1965]: 862C82C00C5: removed
Sep  4 07:27:41 lpul-efa postfix/smtp[2685]: D3BCF2C00C6: enabling PIX workarounds: disable_esmtp delay_dotcrlf for aspmx.l.google.com[74.125.129.27]:25
Sep  4 07:27:57 lpul-efa postfix/smtp[2685]: D3BCF2C00C6: to=<user@mydomain.net>, relay=aspmx.l.google.com[74.125.129.27]:25, delay=17, delays=0.13/0/12/4, dsn=2.0.0, status=sent (250 2.0.0 OK 1378272477 se2si18215131pbc.286 - gsmtp)
Sep  4 07:27:57 lpul-efa postfix/qmgr[1965]: D3BCF2C00C6: removed
darky83
Site Admin
Post by darky83 »
Weird thing, by default this should be set to 50MB
What does the following say when you run it?
postconf -n | grep message_size_limit
and when you search for 10485760 in /etc/ does that show any hits?
cd /etc
grep -R 10485760 *
maik
Post by maik »
root@efa:~# postconf -n | grep message_size_limit
message_size_limit = 512000000
root@efa:~# cd /etc/
root@efa:/etc# grep -R 10485760 *
root@efa:/etc#
I had both of these thoughts and have even grepped through the entire filesystem for 10485760 and found nothing. I also thought maybe 10M would be present somewhere but didn't find anything relevant. So weird.
darky83
Site Admin
Post by darky83 »
Weird indeed, if postfix says that the size limit is 512000000 but in the logs you show it says that it exceeds the size limit of 10MB then something inside postfix seems to be wrong.. :S
Maybe a silly question but did you try a reboot ?
maik
Post by maik »
Yep. Felt a little crazy doing it, but it didn't make a difference. I feel like there's some obvious answer here. Could it be Exchange kicking it back to Postfix and then postfix generating that message? That seems pretty off the wall but I'm just grasping at straws right now.
ge2000
Post by ge2000 »
In my setup in /etc/MailScanner/MailScanner.conf there are several size options, like Maximum Message Size = %rules-dir%/max.message.size.rules or ClamAVmodule Maximum File Size = 10000000 # (10 Mbytes).
Maybe one of those are teasing you?
--Ge
maik
Post by maik »
So the last post at http://www.linuxquestions.org/questions ... it-829722/ set me straight. The bounce log message is coming from postfix/smtp which is the smtp client which sends the outgoing message. In the log it says it's coming from mail. which is the downstream Exchange server. That's the problem right there (as if it were any surprise!).
darky83
Site Admin
Post by darky83 »
indeed it says so clearly... how did I miss that :|
