Hello there,
I've been using EFA for some months right now and i got a problem today. When i try to go on my MailWatch, i get this message
"Cannot find configuration value: VirusScanners in /etc/MailScanner/MailScanner.conf"
Just before i get this error, i change the spamassassin spam score value in the file. I try to see witch value was missing but i can't find it :/.
Someone has an idea ?
Can't access the webgui (MailWatch)
Re: Can't access the webgui (MailWatch)
search for
compare the .conf-file with your backuped files
(/var/EFA/backup - newest backup*.tar.gz) same path
thats the standardVirus Scanners = clamd
Thank you DaN for your solution.
I already had the value at "Virus Scanner = clamd" so i tried to compare with a backup file. I first didn't found anything after doing the whole file.
I then did a new efa vm to compare and I find out that there were tab before some line and that was causing the problem.
Now everything is working
Thanks alot
Thanks alot
