Active Directory
Active Directory
Is the recipient check with Active Directory working? I tryed an unknown user with telnet (rcpt to) and the server accepted it.
Re: Active Directory
k thank you, keep the excellent work!
We'll deploy EFA 0.3 in our organization next monday
perforator
Hope this will work with LDAP!?
That would be a better solution as not all are using AD, but AD does have support for LDAP as other directory services and user account systems.
