I have an EFA installation that started out as 3.0.0.9, and has been upgraded to 3.0.1.1.
Unfortunately mailgraph does not seem to work from the "Tools" menu.
When i click on "View Mailgraph Statistics" the page https://<server>/mailscanner/mailgraph.php loads with the head of the page ok, but the iframe, where mailgraph should be putting data is empty.
However, using the direct URL https://<server>/cgi-bin/mailgraph.cgi works. This is the same URL that mailgraph.php would be embedding into the iframe, except that the calling php-file /var/www/html/mailscanner/mailgraph.php tries to embed ../cgi-bin/mailgraph.php, which isn't there. Changing the script to call ../cgi-bin/mailgraph.cgi doesn't help either. The iframe stays empty.
I'm at a loss with this, tried with 4 browsers (Chrome, Firefox, IE, Edge) but no difference.
I ended up changing mailgraph.php to
<?php
require_once("./functions.php");
session_start();
require('login.function.php');
$refresh = html_start("Tools/Links",0,false,false);
<iframe src="../cgi-bin/mailgraph.cgi" width="960px" height="1024px">
<a href="../cgi-bin/mailgraph.cgi">Click here for Mailgraph Statistics</a>
</iframe>
<?php
html_end();
dbclose();
Moreover, the mailgraph.cgi breaks https, causing a browser warning due to mixed content, the reason being that Tobi's gif at http://oss.oetiker.ch/rrdtool/.pics/rrdtool.gif is embedded ia plain https. I changed the cgi to call https://oss.oetiker.ch/rrdtool/.pics/rrdtool.gif and the browser is happy.
Maybe some intelligence could be added to the script, to check whether it is being called over https or https.
Any ideas what could have gone wrong here?
Regards,
jr
