Configure E.F.A after installation.
Locked
darky83
Site Admin
Post by darky83 »
After the system is rebooted open a web browser and browse to the IP of your EFA server.
To get EFA working you will need to create a domain admin user and add domains to that user.
For example if you have 2 company's you create two domain admins and add the domains of that specific company to the specific domain admin.
If you have only one company or don't plan to give other users access as domain admin it is possible to create just one domain admin.
Login using the account you created during the system setup:
Once logged in click Settings.
Then click Accounts.
Then click Create account.
Create the user for the domains you want to add and click create.
When the user is created click on edit next to Profile Settings.
Change the user type to Domain Admin
Note: Due to a bug in baruwa you need to change the default 0.0 score settings to 0 (Or choose your own score settings, 0 = system default settings)
Then select the + below Domains managed.
Add the domain name you want to receive mail for.<br />
Next we need to select where the mail should go to so go back to Settings.
Click on the domain name you want to configure.
Click on Add next to Delivery SMTP Servers.
And add the IP or hostname for your internal mailserver.
Now E.F.A is configured to receive and forward mail to your mail server.
Locked
