I cannot remember setting a user/pass for webmin, but the normal user admin does not work.
Before I enter the shell reseting pwd for webmin (if I can figure it out thru their website), what was it suposed to be?
The same user to enter the EFA shell menu?
Using webmin? user/passw?
Re: Using webmin? user/passw?
It is the root user and root password
Okay, then I'll need to reset my root password
My root password is a kind that normally crashes .NET type website login pages, but here it is also not accepted.
I will google for resetting pwd root in CentOS.
Tnx for the quick reply!
