Error: Cannot retrieve metalink for repository: epel. Please verify its path and try again
Update to Version 3.0.0.9 FAILED. Updates cancelled.
Rebooting shows SQLGrey failing to start - didn't catch the error on boot, but restarting sqlgrey service gives this:
Starting SQLgrey: Can't locate Net/Server/Multiplex.pm in @INC (@INC contains: /usr/local/lib64/perl5 /usr/local/share/perl5 /usr/lib64/perl5/vendor_perl /usr/share/perl5/vendor_perl /usr/lib64/perl5 /usr/share/perl5 .) at /usr/sbin/sqlgrey line 33.
BEGIN failed--compilation aborted at /usr/sbin/sqlgrey line 33.
The EFA menu has option 14 for Updating so parts have updated, but at this point no email comes in (presumably because SQLGrey isn't running).
I've previously installed 3.00.8 and updated to 3.0.0.9 on another machine using the same process so not sure what's gone wrong. Also, rebuilt from initial VM appliance and got the same result. Rolling back the snapshot for now, but would appreciate any guidance.
