Behind the forefront-proxy, the call /usr/local/sbin/EFA-Update -check answers :
[EFA] Getting latest version number from http://dl.efa-project.org
ERROR: The version file downloaded does not seem to be valid.
ERROR: exiting now
Normally, I help myself with such proxy statements like this in /etc/bashrc:
export http_proxy=http://user:pwd@ip:port. So I can access the internet from bash.
but EFA-Update -check won´t work.
Any help?
Update behind MS-ForeFront
Re: Update behind MS-ForeFront
same problem here.. hoping anyone can help..
thank you in advance...
No way to go around the proxy with an exception?
I think wget, yum, and friends have different ways of setting the proxy.
Also check this out:
http://stackoverflow.com/questions/1121 ... xy-in-wget
The hint with wgetrc works!
Thank You!
Thank You!
