I'm being told to disable link tracking so we don't get the messages "MailScanner has detected a possible fraud attempt from ... claiming to be"
How can I do that?
How to disable link tracking
tpospeshil
Re: How to disable link tracking
I searched the forum, but not using Google. Apparently my search skills suck, because I only found info about white-listing sites.
Thanks for your help
google has a better search algorighm than the forum software. It's a useful tip that works on many websites.
Did you find the setting you need?
tpospeshil
Yes, I'm good to go. Thanks
