unable to preview messages
ge2000
Post by ge2000 » 29 Jan 2013 21:31
Almost everything is working fine. Except when trying to view a message like http://efa/messages/preview/07A16B3ACF.AEA52 an error is shown.
The message is:
Page unavailable
Sorry the requested page is unavailable due to a server malfunction.
Have I broke something or does anyone know where to look?
Kind regards,
Ge
darky83
Site Admin
Re: unable to preview messages
Post by darky83 » 30 Jan 2013 07:30
This should be logged in the baruwa log file:
/var/log/baruwa/celeryd.log
this is most likely a rabbitmq connection error.
ge2000
Post by ge2000 » 30 Jan 2013 09:02
You're right. There are hundreds of these errors. Although everything else seems to work fine I assume there is more broken than the preview only.
I will look into this but if you have any suggestions to start with please let me know.
Thanks,
Ge
[2013-01-30 10:41:41,384: ERROR/MainProcess] Consumer: Connection Error: Socket closed. Trying again in 32 seconds...
[2013-01-30 10:42:16,421: ERROR/MainProcess] Consumer: Connection Error: Socket closed. Trying again in 32 seconds...
[2013-01-30 10:42:51,445: ERROR/MainProcess] Consumer: Connection to broker lost. Trying to re-establish connection...
Traceback (most recent call last):
  File "/usr/lib/pymodules/python2.6/celery/worker/consumer.py", line 274, in start
    self.reset_connection()
  File "/usr/lib/pymodules/python2.6/celery/worker/consumer.py", line 483, in reset_connection
    self.connection = self._open_connection()
  File "/usr/lib/pymodules/python2.6/celery/worker/consumer.py", line 529, in _open_connection
    self.app.conf.BROKER_CONNECTION_MAX_RETRIES)
  File "/usr/lib/pymodules/python2.6/kombu/connection.py", line 184, in ensure_connection
    interval_start, interval_step, interval_max)
  File "/usr/lib/pymodules/python2.6/kombu/utils/__init__.py", line 102, in retry_over_time
    return fun(*args, **kwargs)
  File "/usr/lib/pymodules/python2.6/kombu/connection.py", line 119, in connect
    return self.connection
  File "/usr/lib/pymodules/python2.6/kombu/connection.py", line 444, in connection
    self._connection = self._establish_connection()
  File "/usr/lib/pymodules/python2.6/kombu/connection.py", line 410, in _establish_connection
    conn = self.transport.establish_connection()
  File "/usr/lib/pymodules/python2.6/kombu/transport/pyamqplib.py", line 252, in establish_connection
    connect_timeout=conninfo.connect_timeout)
  File "/usr/lib/pymodules/python2.6/kombu/transport/pyamqplib.py", line 51, in __init__
    super(Connection, self).__init__(*args, **kwargs)
  File "/usr/lib/pymodules/python2.6/amqplib/client_0_8/connection.py", line 140, in __init__
    (10, 30), # tune
  File "/usr/lib/pymodules/python2.6/amqplib/client_0_8/abstract_channel.py", line 89, in wait
    self.channel_id, allowed_methods)
  File "/usr/lib/pymodules/python2.6/amqplib/client_0_8/connection.py", line 198, in _wait_method
    self.method_reader.read_method()
  File "/usr/lib/pymodules/python2.6/amqplib/client_0_8/method_framing.py", line 215, in read_method
    raise m
IOError: Socket closed
[2013-01-30 10:42:54,449: ERROR/MainProcess] Consumer: Connection Error: Socket closed. Trying again in 2 seconds...
[2013-01-30 10:42:59,456: ERROR/MainProcess] Consumer: Connection Error: Socket closed. Trying again in 4 seconds...
ge2000
Post by ge2000 » 30 Jan 2013 09:41
ok, found that baruwa password was wrong. After changing it the errors are gone. Will do some more testing.....
root@efa1:/var/log/rabbitmq# rabbitmqctl change_password baruwa ***************
Changing password for user "baruwa" ...
...done.
Edit: It works fine now..... no idea why the installation password wasn't working
mw308
Post by mw308 » 27 Mar 2013 16:53
Hi Ge
I am getting the same error and according to the rabbitmq log the user baruwa cannot log onto the database. In my install (script not VM as using Hyper-V) it chose a random password for the baruwa user which is encrypted in the config files - how did you know what to change it to in rabbitmqctl?
Many thanks in advance
darky83
Site Admin
Post by darky83 » 27 Mar 2013 17:36
The build script creates a random password and puts this random password in the config files and sets this random password in rabbitmq
If you change the rabbitmq password manually you should also change this in the baruwa config file: /etc/baruwa/settings.py
look for:
BROKER_PASSWORD =
Then restart baruwa and you should be ready to go.
mw308
Post by mw308 » 28 Mar 2013 08:47
Changing it as above appears to work perfectly.
Many thanks!
