I just installed EFA 3.0.0.8 on a KVM virtual machine using sligthly modified ks-script: http://ponky.org/ks.cfg (changed fs to ext4). I've tried this two times now and always ended up in situation where mails get in a loop because clamd socket is not found:
http://pastebin.com/f63taEHQ
When I run 'service clamd restart' I get
clamd: unrecognized service
During the installation I saw some errors regarding user:clam, but iirc this is about epel-repo version of clamav?
Clamd missing on fresh install of 3.0.0.8 ?
Re: Clamd missing on fresh install of 3.0.0.8 ?
Yeah, clam did not install.
Not a bit surprised, though. We have an issue, the latest clamav has some changes.
I already have it fixed, but for in order for you to successfully build, I will need to port the fix into the 3.0.0.8 branch.
If I have some time tonight I will work on this.
Nice. Could you ping me on irc when you commit the changes?shawniverson wrote:Yeah, clam did not install.
Still working on this...didn't get far the other day when github was down...
