My installation is an EFA box between the internet end the Exchange
So EFA receive messages
1 - from internet to be delivered to Exchange for our domains
2 - from Exchange to be delivered to the internet
Exchange have the ip 10.1.1.125 that is whitelisted so it is even passed it have Spam Whitelisted flag even set to true
Watching Mailwatch I cant see spam report but I see the score
If there is a score it is impossible that there is no report so if I query db i find the report
select spamreport from maillog where id="40CC2A1F94.A6B95";
Non Spam (no watermark or sender address) (Presente in Whitelist), SpamAssassin (cached, punteggio=-10.793, richiesto 4, ALL_TRUSTED -9.00, AWL 0.26, BAYES_00 -1.20, BAYES_WL -0.30, BAYES_ZERO -0.90, H_HOSTDOM_EQ_MAILDOM -0.15, H_PTRDOM_EQ_MAILDOM -0.45, H_SAME_DOMAIN -0.30, H_SAME_HOST -0.10, IT_FROM -0.02, IT_ON_NON_IT_HOST 1.10, IT_SRV -0.02, MYDOMAIN_D -0.01, SQLGREY_SLOW 0.30)
Outgoing email are an half of the total, there is a way to NOT SCAN these emails with antivirus and/or spamassassin to save cpu ?
Spam Check on Ip Whitelist
Re: Spam Check on Ip Whitelist
Some MailScanner rules override the whitelist, such as this one..
You can create a ruleset for this one and put your Exchange server in it if you want to use it just for incoming mail.
# Do you want to check watermarks?
Check Watermarks With No Sender = yes
