Hello
Hopefully this is an easy one, my mailwatch has stopped updaging and cant view quaratined messages, search for quaratined messages etc. It just stopped logging/updating as of 2 days ago but still passes messages?
Have updated to 3.0.0.8 and several reboots.
Please help
James
Mailwatch not updating
Re: Mailwatch not updating
Check your date and time on your system...it may be off...
Is mysql running/ok?
jamessmith2k
Yes MYSQL is running fine, maillog table is never poupulated, i cleardd the table in case it was a size limit thing so the so table is empty (colums exist but no data).
Okay, without more info we can't get anywhere, do you have anything in your logs (/var/log) that would help us narrow in on the problem?
