My EFA send all emails to Exchange after analisis
But it send also email for users that do not exists
There is a way to test user existance and generate in EFA NDR reports ?
test email existance
Re: test email existance
Ok, but :
1) It seeme that thhis script import usernames and not mai address
2) There is a way to not pass all domain.com to Exchange server but only mailboxes in the imported user table ?
3) There is a way that efa generate NDR not for all messages with unknown user but only for messages not classified as spam ?
I tried to populate email addresses in efa/mysql using ldap
It works but i think that it can be unstable, i have a problem retrieving too many rows
but i solved in other way
vi /etc/postfix/main.cf
Modify the row smtpd_recipient_restrictions adding reject_unverified_recipient
So postfix check mailbox existance of our mailboxex in our Exchange each time someone try to put a message
Postifix give an error 450 that is non know in RFC as Maibox Unknown so i add these two lines to give the same response as efa was the real final server
unverified_recipient_reject_code = 550
unverified_recipient_reject_reason = Casella di posta non trovata sui nostri sistemi
Good postfix feature. I think many people would like this option.
https://github.com/E-F-A/v3/issues/218
hi,
i give it a try, and it was not working ... The first incoming emails are ok, but suddently every valid email address are rejected ...
We have many CPanel shared hosting servers, possible that this will not work correctly in our case.
Our MailFoundry was able to cache the invalid email addresses, don't know how they did that ...
I have populated /etc/postfix/recipient_acces with all email addresses from Exchange.
smtpd_recipient_restrictions = permit_sasl_authenticated, permit_mynetworks, reject_unauth_destination, reject_non_fqdn_recipient, reject_unknown_recipient_domain, check_recipient_access hash:/etc/postfix/recipient_access, reject_unverified_recipient
Non existing recipient still goes through, adding reject at the end to smtpd_recipient_restrictions works for me:
smtpd_recipient_restrictions = permit_sasl_authenticated, permit_mynetworks, reject_unauth_destination, reject_non_fqdn_recipient, reject_unknown_recipient_domain, check_recipient_access hash:/etc/postfix/recipient_access, reject_unverified_recipient, reject
2019-12-13 09:56:01 SMTP Error: The following recipients failed: email@domain.xx: : Recipient address rejected: Access denied
Message sending failed.
Chris
You dont need to do this
Is better to do an AD query to check mail existance
## File di configurazione LDAP per la verifica degli email address da accettare
relay_recipient_maps = ldap:/etc/postfix/ldap_relay_recipient_maps.cf
Creare il file di configurazione che utilizza un utente ad hoc senza alcun tipo di permesso per la query :
vi /etc/postfix/ldap_relay_recipient_maps.cf
#/etc/postfix/ldap_relay_recipient_maps.cf
# Configurazione LDAP per query recipients consentiti
# Restituisce sia le email degli utenti che quelle dei gruppi
# Server
server_host = 10.1.1.120 10.1.1.121
server_port = 389
# Search on entire domain
search_base = DC=gruppocomet,DC=net
version = 3
#scope = sub
bind_dn = cometnt\efaldap
bind_pw = YOURADUSERPASSWORD
bind = yes
query_filter = (|(proxyAddresses=smtp:%s) (proxyAddresses=SMTP:%s))
result_attribute = mail
# Server
server_port = 389
version = 3
#scope = sub
bind = yes
