With my client i send email to Exchange
Exchange pass to efa that send to end user recipient
If I send to an unknown user or unresolved domain EFA generate a NDR back to me
but
When destination respond :
host mail.register.it[195.110.124.132] said: 452 4.1.1 <USER@DOMAIN.it> 4.2.2 mailbox full (in reply to RCPT TO command)
It stay in postfix queue and then efa doesnt generate NDR,
It is correct so ?
						NDR from Efa
Re: NDR from Efa
How log does the mail stays in queue?
						Re: NDR from Efa
Yes, because you get 4xx status code,
meaning that the remote server saying to you "try again later".
so the EFA will try to send this message again.
read this for more info:
http://jrs-s.net/2013/04/17/configuring ... n-postfix/
Regards,
Zohman.
the default is 5 days. (maximal_queue_lifetime)DaN wrote:How log does the mail stays in queue?
Regards,
Zohman.
Re: NDR from Efa
Yes, it is 5 days, i think that can be good the default
but
there is a way to generate a NDR to inform that the message are still in queue after 1 hour ?
						but
Re: NDR from Efa
yes.. "delay_warning_time" but you need postfix 3.0 and later...nicola.piazzi wrote:Yes, it is 5 days, i think that can be good the default
but
and EFA come with postfix 2.6, it may be on the next EFA version.
Zohman.
Re: NDR from Efa
ok, thx,
Il will be on E.F.A.3.0.0.9 ?
You know release date ?
Re: NDR from Efa
need shawniverson respond.nicola.piazzi wrote:ok, thx,
Re: NDR from Efa
3.0.0.9 development at 58%, 10/24 issues open ...no ETA yet (sorry, gotta pay the bills with my other life)
Just added postscreen/postfix update to 3.0.0.9 milestone.
https://github.com/E-F-A/v3/issues/205
https://github.com/E-F-A/v3/issues/217
Current milestone status...
https://github.com/E-F-A/v3/milestones/3.0.0.9
