Messages per day
Messages per day
Silly question but how do I see how many messages per day or per second my EFA server is processing
Re: Messages per day
Per day:
right corner under "Today's Totals" in your webinterface (mailscanner)
See also:
Reports, Total Messages by Date
<server>/mailscanner/rep_total_mail_by_date.php
anybody ever seen this.... I get it when I go to the MailScanner web interface
144: Table './mailscanner/maillog' is marked as crashed and last (automatic?) repair failed
SQL:
SELECT
COUNT(*) AS processed,
SUM(
CASE WHEN (
(virusinfected=0 OR virusinfected IS NULL)
AND (nameinfected=0 OR nameinfected IS NULL)
AND (otherinfected=0 OR otherinfected IS NULL)
AND (isspam=0 OR isspam IS NULL)
AND (ishighspam=0 OR ishighspam IS NULL)
AND (ismcp=0 OR ismcp IS NULL)
AND (ishighmcp=0 OR ishighmcp IS NULL)
) THEN 1 ELSE 0 END
) AS clean,
ROUND((
SUM(
CASE WHEN (
) THEN 1 ELSE 0 END
)/COUNT(*))*100,1
) AS cleanpercent,
SUM(
CASE WHEN
virusinfected>0
THEN 1 ELSE 0 END
) AS viruses,
ROUND((
SUM(
CASE WHEN
virusinfected>0
THEN 1 ELSE 0 END
)/COUNT(*))*100,1
) AS viruspercent,
SUM(
CASE WHEN
nameinfected>0
AND (virusinfected=0 OR virusinfected IS NULL)
THEN 1 ELSE 0 END
) AS blockedfiles,
ROUND((
SUM(
CASE WHEN
nameinfected>0
THEN 1 ELSE 0 END
)/COUNT(*))*100,1
) AS blockedfilespercent,
SUM(
CASE WHEN
otherinfected>0
THEN 1 ELSE 0 END
) AS otherinfected,
ROUND((
SUM(
CASE WHEN
otherinfected>0
THEN 1 ELSE 0 END
)/COUNT(*))*100,1
) AS otherinfectedpercent,
SUM(
CASE WHEN
isspam>0
THEN 1 ELSE 0 END
) AS spam,
ROUND((
SUM(
CASE WHEN
isspam>0
THEN 1 ELSE 0 END
)/COUNT(*))*100,1
) AS spampercent,
SUM(
CASE WHEN
ishighspam>0
THEN 1 ELSE 0 END
) AS highspam,
ROUND((
SUM(
CASE WHEN
ishighspam>0
THEN 1 ELSE 0 END
)/COUNT(*))*100,1
) AS highspampercent,
SUM(
CASE WHEN
ismcp>0
THEN 1 ELSE 0 END
) AS mcp,
ROUND((
SUM(
CASE WHEN
ismcp>0
THEN 1 ELSE 0 END
)/COUNT(*))*100,1
) AS mcppercent,
SUM(
CASE WHEN
ishighmcp>0
THEN 1 ELSE 0 END
) AS highmcp,
ROUND((
SUM(
CASE WHEN
ishighmcp>0
THEN 1 ELSE 0 END
)/COUNT(*))*100,1
) AS highmcppercent,
SUM(size) AS size
FROM
maillog
WHERE
date = CURRENT_DATE()
AND
(1=1)
SQL:
SELECT
SUM(
CASE WHEN (
) THEN 1 ELSE 0 END
) AS clean,
ROUND((
SUM(
CASE WHEN (
) THEN 1 ELSE 0 END
)/COUNT(*))*100,1
) AS cleanpercent,
SUM(
CASE WHEN
virusinfected>0
THEN 1 ELSE 0 END
) AS viruses,
ROUND((
SUM(
CASE WHEN
virusinfected>0
THEN 1 ELSE 0 END
)/COUNT(*))*100,1
) AS viruspercent,
SUM(
CASE WHEN
nameinfected>0
THEN 1 ELSE 0 END
) AS blockedfiles,
ROUND((
SUM(
CASE WHEN
nameinfected>0
THEN 1 ELSE 0 END
)/COUNT(*))*100,1
SUM(
CASE WHEN
otherinfected>0
THEN 1 ELSE 0 END
) AS otherinfected,
ROUND((
SUM(
CASE WHEN
otherinfected>0
THEN 1 ELSE 0 END
)/COUNT(*))*100,1
SUM(
CASE WHEN
isspam>0
THEN 1 ELSE 0 END
) AS spam,
ROUND((
SUM(
CASE WHEN
isspam>0
THEN 1 ELSE 0 END
)/COUNT(*))*100,1
) AS spampercent,
SUM(
CASE WHEN
ishighspam>0
THEN 1 ELSE 0 END
) AS highspam,
ROUND((
SUM(
CASE WHEN
ishighspam>0
THEN 1 ELSE 0 END
)/COUNT(*))*100,1
SUM(
CASE WHEN
ismcp>0
THEN 1 ELSE 0 END
) AS mcp,
ROUND((
SUM(
CASE WHEN
ismcp>0
THEN 1 ELSE 0 END
)/COUNT(*))*100,1
) AS mcppercent,
SUM(
CASE WHEN
ishighmcp>0
THEN 1 ELSE 0 END
) AS highmcp,
ROUND((
SUM(
CASE WHEN
ishighmcp>0
THEN 1 ELSE 0 END
)/COUNT(*))*100,1
SUM(size) AS size
FROM
maillog
WHERE
AND
(1=1)
Go into EFA-Configure and run MySQL recovery...
