Re-send emails in quarantine
kingramon0
I might be facing the need to restore our Exchange database from a backup. If that becomes necessary, is it possible to have all the stored messages in EFA after a certain date be redelivered so we don't lose a days worth of emails?
Re: Re-send emails in quarantine
Yes, with a little effort.
kingramon0
So, how would I do it?
Glad you asked
1) Head over to /var/spool/MailScanner/quarantine
2) Look for the dir(s) you want, labeled by date
3) Find the nonspam dir
4) Copy the emails from the nonspam dir to /var/spool/postfix/incoming
5) Go grab a beer for a job well done.
kingramon0
Wow, thanks!
I'm definitely going to need a lot of step 5's, but this will make it so much easier!
Thanks again!
Thanks again!
kingramon0
The files are just sitting there. Other mail is coming in but it doesn't grab the files I copied. I tried postqueue -f, but nothing. Any ideas?
kingramon0
I figured out that I need to chmod u+x and remove everything trailling the period in the file name. However, the messages get put in the corrupted queue.
My Mailscanner.conf has:
# Do you want to quarantine the original *entire* message as well as
# just the infected attachments?
# When you quarantine an entire message, do you want to store it as
# raw mail queue files (so you can easily send them onto users) or
# as human-readable files (header then body in 1 file)?
I'm guessing that is why. Changing it now won't help me. Is there something else I can do to the files to make it accept them?
Well, crud, they aren't queue files. Let me do a little tinkering.
I think we can still do this, but it may require passing the emails through a little script.
kingramon0
I found some ways around this that should be good enough, so don't worry about it. Fortunately, it's only a dozen or so users that I need to retrieve stuff for, and I only have two left.
Your SummitStor project is intriguing though. I might need to stalk you on that.
