Where can i change this? i have checked in Kam.cf but cannot find it in their?
i can see the score is 2.0 and need to increase this
FREEMAIL_FORGED_REPLYTO
Re: FREEMAIL_FORGED_REPLYTO
[root@efa ~]# cd /var/lib/spamassassin/
[root@efa spamassassin]# grep -R FREEMAIL_FORGED_REPLYTO *
3.004000/updates_spamassassin_org/30_text_pt_br.cf:lang pt_BR describe FREEMAIL_FORGED_REPLYTO Email gratuito usado no Reply-To, mas n▒o no From:
3.004000/updates_spamassassin_org/50_scores.cf:score FREEMAIL_FORGED_REPLYTO 1.199 2.503 1.204 2.095
3.004000/updates_spamassassin_org/20_freemail.cf:meta FREEMAIL_FORGED_REPLYTO __freemail_hdr_replyto && !FREEMAIL_FROM && !__freemail_safe
3.004000/updates_spamassassin_org/20_freemail.cf:describe FREEMAIL_FORGED_REPLYTO Freemail in Reply-To, but not From
3.004000/updates_spamassassin_org/20_freemail.cf:score FREEMAIL_FORGED_REPLYTO 0.1Customizing spamassassin scores
I don't know what the line from 50_scores.cf means. Perhaps someone else can explain what the 4 numbers are for. Otherwise, I'd just try modifing the local.cf to adjust the FREEMAIL_FORGED_REPLYTO spamassassin score.
Good luck!
twstevensuk
Thanks, The issue is that i cannot see this option in /etc/mail/spamassain/local.cf ?
Below is my local.cf file
# This is the right place to customize your installation of SpamAssassin.
# See 'perldoc Mail::SpamAssassin::Conf' for details of what can be
# tweaked.
# Only a small subset of options are listed below
# Add *****SPAM***** to the Subject header of spam e-mails
# rewrite_header Subject *****SPAM*****
# Save spam messages as a message/rfc822 MIME attachment instead of
# modifying the original message (0: off, 2: use text/plain instead)
# report_safe 1
# Set which networks or hosts are considered 'trusted' by your mail
# server (i.e. not spammers)
# trusted_networks 212.17.35.
# Set file-locking method (flock is not safe over NFS, but is faster)
# lock_method flock
# Set the threshold at which a message is considered spam (default: 5.0)
# required_score 5.0
# Use Bayesian classifier (default: 1)
# use_bayes 1
# Bayesian classifier auto-learning (default: 1)
# bayes_auto_learn 1
# Set headers which may provide inappropriate cues to the Bayesian
# classifier
# bayes_ignore_header X-Bogosity
# bayes_ignore_header X-Spam-Flag
# bayes_ignore_header X-Spam-Status
# Some shortcircuiting, if the plugin is enabled
ifplugin Mail::SpamAssassin::Plugin::Shortcircuit
# default: strongly-whitelisted mails are *really* whitelisted now, if the
# shortcircuiting plugin is active, causing early exit to save CPU load.
# Uncomment to turn this on
# shortcircuit USER_IN_WHITELIST on
# shortcircuit USER_IN_DEF_WHITELIST on
# shortcircuit USER_IN_ALL_SPAM_TO on
# shortcircuit SUBJECT_IN_WHITELIST on
# the opposite; blacklisted mails can also save CPU
# shortcircuit USER_IN_BLACKLIST on
# shortcircuit USER_IN_BLACKLIST_TO on
# shortcircuit SUBJECT_IN_BLACKLIST on
# if you have taken the time to correctly specify your "trusted_networks",
# this is another good way to save CPU
# shortcircuit ALL_TRUSTED on
# and a well-trained bayes DB can save running rules, too
# shortcircuit BAYES_99 spam
# shortcircuit BAYES_00 ham
endif # Mail::SpamAssassin::Plugin::Shortcircuit
# tweaked.
# report_safe 1
# lock_method flock
# use_bayes 1
# classifier
Because you have to add it into your local.cf file yourself.
You can score it more or less according to your preference.
score FREEMAIL_FORGED_REPLYTO 4.0Re: FREEMAIL_FORGED_REPLYTO
hi guys,
i've also tried to raise the score for FREEMAIL_FORGED_REPLYTO, but it seems like it doesn't work.
EFA still uses the old score.
i've added the line at the end in /etc/mail/spamassain/local.cf:
but efa still uses 2.10 score:
am i doing something wrong ?
# use_bayes 1
# classifier
# Whether to decode non- UTF-8 and non-ASCII textual parts and recode
# them to UTF-8 before the text is given over to rules processing.
# normalize_charset 1
Spam Report:
-7.61 AWL Adjusted score from AWL reputation of From: address
0.80 BAYES_50 Bayes spam probability is 40 to 60%
2.10 FREEMAIL_FORGED_REPLYTO Freemail in Reply-To, but not From
1.00 HK_RANDOM_REPLYTO
16.00 KAM_SEX_EXPLICIT Subject or body indicates Sexually Explicit material
0.00 SPF_FAIL SPF: sender does not match SPF record (fail)
0.00 SPF_HELO_NONE SPF: HELO does not publish an SPF RecordRe: FREEMAIL_FORGED_REPLYTO
no one here who can help me in this case ?
a lot of spam mails with FREEMAIL_FORGED_REPLYTO are getting through EFA because of this non working rule
thanks in advance
thanks in advance
score FREEMAIL_FORGED_REPLYTO 4.0 <<< move this line outside of the if/endif blocks as you created a dependency on the Shortcircuit plugin
endif # Mail::SpamAssassin::Plugin::ShortcircuitCode: Select all
/etc/mail/spamassassin/v320.pre“We are stuck with technology when what we really want is just stuff that works.” -Douglas Adams
