minor issue in default MailScanner.conf - "Notify Senders = no" multiple times
twoeyes
Post by twoeyes »
I'm reading through MailScanner.conf, reviewing whatever custom settings we had on our ESVA setup, and noticed in the " Notifications back to the senders of blocked messages" section, there were multiple "Notify Senders = " lines. The ESVA config file I am comparing against, has different options, e.g. "Notify Senders Of Viruses = no". It looks like a search and replace typo or similar.
It's a minor thing, and doesn't affect our install. Not sure about other people.
Thanks for giving ESVA users something current to use!
darky83
Site Admin
Re: minor issue in default MailScanner.conf - "Notify Senders = no" multiple times
Post by darky83 »
Hmm I just checked but all my systems look fine.
When you deployed the VM, from which version did you started (3.0.0.8 ?) and did you use the VMware or the Hyper-V version?
Maybe there is a bug in one of the versions but I have not found it yet :)
darky83
Site Admin
Post by darky83 »
Ah found it.
the build from 3.0.0.8 had a search and replace typo..
Can you post the complete "Notifications back to the senders of blocked messages" section that you now see?
The section should be like below,all sections that have "Notify Senders " are messed up in your setup I guess.
# Notifications back to the senders of blocked messages
# Do you want to notify the people who sent you messages containing
# viruses or badly-named filenames?
Notify Senders = no
# *If* "Notify Senders" is set to yes, do you want to notify people
# who sent you messages containing viruses?
# The default value has been changed to "no" as most viruses now fake
# sender addresses and therefore should be on the "Silent Viruses" list.
# who sent you messages containing attachments that are blocked due to
# their filename or file contents?
Notify Senders Of Blocked Filenames Or Filetypes = yes
# being too small or too large?
Notify Senders Of Blocked Size Attachments = no
# who sent you messages containing other blocked content, such as
# partial messages or messages with external bodies?
Notify Senders Of Other Blocked Content = yes
# If you supply a space-separated list of message "precedence" settings,
# then senders of those messages will not be warned about anything you
# rejected. This is particularly suitable for mailing lists, so that any
# MailScanner responses do not get sent to the entire list.
Never Notify Senders Of Precedence = list bulk
darky83
Site Admin
Post by darky83 »
twoeyes
Post by twoeyes »
Oops. Guess I wasn't subscribed to get replies to the thread.
We're running in Xen actually, so, I used the magical build script. I've never used something like that before, I was pretty impressed.
Basically all those lines said: "Notify Senders = no"
Here's most of it... I skipped the first few lines that I customized already:
Notify Senders = no
Notify Senders = no
Notify Senders = no
Notify Senders = no
:violence-hammer:
Doh!
darky83
Site Admin
Post by darky83 »
Will try to fix this in the next release, for a quick fix you can copy / paste in my section above that is how it should be.
