After 3.0.0.8 upgrade can't login to mailwatch
netone
Post by netone »
few days ago I have updated EFA to 3.0.08 version from 3.0.0.7
Now I try to login to mailwatch but after 3 or 4 seconds the login page reload without error. I have tried to reset admin password from mysql interface but ...nothings.
Someone can help me?
Many thanks in advance.
DaN
Re: After 3.0.0.8 upgrade can't login to mailwatch
Post by DaN »
you mean you tried this?
https://efa-project.org/wiki/Lost_password
netone
Post by netone »
Thanks for your answer.
Yes I have already resetted the password via sql commands but, in effect, I don't have a login error. The page is only reloaded with the login fields after few seconds without errors.
Do you use AD, check this out if so.
https://github.com/E-F-A/v3/blob/master/RELEASENOTES
