Way to import 100+ new users?
Is there a way to import new users in EFA from like a CSV file instead of having to manually create 100+ new users?
Re: Way to import 100+ new users?
No tool exists for this (yet), but I could create one if you are interested.
That would be wonderful Shawn. We need to add around 160 users and would be nice if we could do a csv or something of the sort to import instead of having to manually create each one. How long would something like that take?
Shouldn't take very long at all. This weekend?
yeah, that would be awesome!
Hey Shawn, no rush, but just checking back with you on this. Thanks!
I was just looking to see if there was such a thing as csv import. Thanks for any tool you can create!
Almost ready. Testing it now.
cdburgess75
Just FYI:
A tool would be awesome. But just wanted to share that I have been able to do this with MS Excel and Webmin. Webmin is a tool that EFA has installed that allows you to dig right to the users mysql table and download the CSV, then edit it and upload. Its very easy to do. A tool would be great, but keep in mind for other areas in mysql that you may want to edit one day (ex:blacklist etc)
/dave
/dave
Import script is ready
To use, create your user.csv file as follows:
username,password,fullname,type
where type = U | A | D
U=user
A=admin
D=domain admin
To append new users:
To overwrite users (except admins and domain admins):
Please note that the csv file is not thoroughly validated. Certain characters, such as a ' or other special characters require proper escaping.
Back up prior to using!
wget https://raw.githubusercontent.com/E-F-A/v3/master/tools/userimport.sh
chmod ugo+x userimport.sh
U=user
A=admin
D=domain admin
sudo /path/to/userimport.sh -f user.csv -a
sudo /path/to/userimport.sh -f user.csv -o
Will this work with the current version 3.0.1.5?
This post if over a year old and wondering if password encryption had changed or not.
Thanks!!
Update: I did try it with 3.0.1.5 and it did work, but the password field looks different but I was able to log in, probably because the default uses more then just md5 encryption, but it did work. I have an attachment that shows the pw's from the import (hilited in yellow) compared to the users added thru user manager in Mailwatch.
Thanks!!
- efa-import-pass.PNG (28.7 KiB) Viewed 15991 times
Is there a way to import users that will be ldap integrated? Have a multi domain EFA configuration using different LDAP servers, but would like to create users without having to have them all log in separately.
