[SOLVED] RAR with EXE
DemonRok
Post by DemonRok »
Hi to all, today i'm having this issue: .rar file with compressed .exe aren't blocked like .zip with compressed .exe
in my /usr/bin/, unrar exist and working correctly in bash.
any idea?
thanks for all!
Re: RAR with EXE
When you run a file -i against the RAR, is it actually a RAR archive?
DemonRok
Re: RAR with EXE
Post by DemonRok »
unrar -i fatt_0031845907.rar do nothing
UNRAR 5.00 beta 3 freeware      Copyright (c) 1993-2013 Alexander Roshal
Usage:     unrar <command> -<switch 1> -<switch N> <archive> <files...>
               <@listfiles...> <path_to_extract\>
<Commands>
  e             Extract files without archived paths
  l[t[a],b]     List archive contents [technical[all], bare]
  p             Print file to stdout
  t             Test archive files
  v[t[a],b]     Verbosely list archive contents [technical[all],bare]
  x             Extract files with full path
<Switches>
  -             Stop switches scanning
  @[+]          Disable [enable] file lists
  ad            Append archive name to destination path
  ag[format]    Generate archive name using the current date
  ai            Ignore file attributes
  ap<path>      Set path inside archive
  c-            Disable comments show
  cfg-          Disable read configuration
  cl            Convert names to lower case
  cu            Convert names to upper case
  dh            Open shared files
  ep            Exclude paths from names
  ep3           Expand paths to full including the drive letter
  f             Freshen files
  id[c,d,p,q]   Disable messages
  ierr          Send all messages to stderr
  inul          Disable all messages
  kb            Keep broken extracted files
  n<file>       Additionally filter included files
  n@            Read additional filter masks from stdin
  n@<list>      Read additional filter masks from list file
  o[+|-]        Set the overwrite mode
  or            Rename files automatically
  ow            Save or restore file owner and group
  p[password]   Set password
  p-            Do not query password
  r             Recurse subdirectories
  sl<size>      Process files with size less than specified
  sm<size>      Process files with size more than specified
  ta<date>      Process files modified after <date> in YYYYMMDDHHMMSS format
  tb<date>      Process files modified before <date> in YYYYMMDDHHMMSS format
  tn<time>      Process files newer than <time>
  to<time>      Process files older than <time>
  ts<m,c,a>[N]  Save or restore file time (modification, creation, access)
  u             Update files
  v             List all volumes
  ver[n]        File version control
  vp            Pause before each volume
  x<file>       Exclude specified file
  x@            Read file names to exclude from stdin
  x@<list>      Exclude files listed in specified list file
  y             Assume Yes on all queries
DemonRok
Re: RAR with EXE
Post by DemonRok »
unrar e fatt_0031845907.rar
Extracting from fatt_0031845907.rar
Extracting  fatt_0031845907_checked_5awg557dfc8ea4a20.exe             OK
All OK
Re: RAR with EXE
Ok.
Next....
Is MailScanner set to scan rar archives like this?
Unrar Command = /usr/bin/unrar
Unrar Timeout = 50
Maximum Archive Depth = 3
Maximum Archive depth can be different depending on how deep you go. 0 disables this.
DemonRok
Re: RAR with EXE
Post by DemonRok »
Well.
in my /etc/MailScanner/MailScanner.conf
Archives Are = zip rar ole
Unrar Timeout = 50
Maximum Archive Depth = 8
DemonRok
Post by DemonRok »
take a look there...
http://lists.mailscanner.info/pipermail ... 02236.html
and do the following:
sudo yum remove unrar
sudo wget https://s3.amazonaws.com/mailborder/releases/stable/4.1.0/unrar-4.2.3-1.el6.rf.x86_64.rpm
sudo rpm -Uvh unrar-4.2.3-1.el6.rf.x86_64.rpm
With unrar-4.2.3 rar files are processed and scanned.
Now Rar with Exe was blocked again on my efa server! :twisted:
Re: [SOLVED] RAR with EXE
DemonRok
Post by DemonRok »
darky83
Site Admin
Post by darky83 »
Is it possible for you to do some more testing?
I created an RPM from the latest unrar version (5.2.7)
Is it possible to test if this one works for you?
(if not you can revert back to the other one)
https://dl.efa-project.org/rpm/CentOS/6/testing/x86_64/unrar-5.2.7-1.el6.x86_64.rpm
Also do you have an specific test case?
In my tests I noticed that with the 5.0.3 version files are checked, so maybe I am testing it different then you are.
DemonRok
Post by DemonRok »
today i'm tring it!
DemonRok
Post by DemonRok »
darky83 wrote:Is it possible for you to do some more testing?
Mail was delivered and not scanned with 5.2.7 too, going back to 4.2.3
darky83
Site Admin
Post by darky83 »
Can you explain how and what you test exactly ? I want to reproduce it :)
DemonRok
Post by DemonRok »
darky83 wrote:Can you explain how and what you test exactly ? I want to reproduce it :)
i sent email to my efa. Attach was rar with simple w32 .exe file on it.
PM me your email, i'll sent you copy of the email.
Exe is not virus...
DemonRok
Post by DemonRok »
LOG from /var/log/maillog
with unrar 4.2.3
sudo less /var/log/maillog | grep CEE1B10252B.A199A
Jun 22 12:46:12 mx2 MailScanner[10774]: Filename Checks: Windows/DOS Executable (CEE1B10252B.A199A Capture2Text.exe)
Jun 22 12:46:12 mx2 MailScanner[10774]: Filetype Checks: No executables (CEE1B10252B.A199A Capture2Text.exe)
Jun 22 12:46:12 mx2 MailScanner[10774]: Saved entire message to /var/spool/MailScanner/quarantine/20150622/CEE1B10252B.A199A
Jun 22 12:46:13 mx2 MailScanner[10774]: Saved infected "Capture2Text.rar" to /var/spool/MailScanner/quarantine/20150622/CEE1B10252B.A199A
Jun 22 12:46:13 mx2 MailScanner[10774]: Saved infected "Capture2Text.exe" to /var/spool/MailScanner/quarantine/20150622/CEE1B10252B.A199A
Jun 22 12:46:15 mx2 MailScanner[10774]: Requeue: CEE1B10252B.A199A to C6952102537
Jun 22 12:46:15 mx2 MailScanner[10774]: Logging message CEE1B10252B.A199A to SQL
with unrar 5.2.7
sudo less /var/log/maillog | grep E2AD91029E0.AEA74
Jun 22 12:44:02 mx2 MailScanner[10774]: Requeue: E2AD91029E0.AEA74 to B99FD10252B
Jun 22 12:44:02 mx2 MailScanner[10774]: Logging message E2AD91029E0.AEA74 to SQL
There is any other log to take a look?
EnricoGTT
Post by EnricoGTT »
I had the same issue and I have solved with new unrar version. :D
Best regards
Enrico
Ramas
Post by Ramas »
Seems to be there are still problems with UNRAR v5 in EFA 3.0.0.9.
With unrar v4.2 working as expected.
I think issue are in space in filename in RAR archive.
With unrar-4.2.3-1.el6.rf.x86_64 in maillog:
Apr 25 22:39:03 smtp MailScanner[28852]: New Batch: Scanning 1 messages, 1115919 bytes
Apr 25 22:39:03 smtp MailScanner[28852]: Filename Checks: Windows/DOS Executable (4413FA0056.A1FAB sample 1.exe)
Apr 25 22:39:03 smtp MailScanner[28852]: Filetype Checks: No executables (4413FA0056.A1FAB sample 1.exe)
Apr 25 22:39:03 smtp MailScanner[28852]: Other Checks: Found 2 problems
Apr 25 22:39:03 smtp MailScanner[28852]: Virus and Content Scanning: Starting
Apr 25 22:39:05 smtp MailScanner[28852]: Spam Checks: Starting
Apr 25 22:39:05 smtp MailScanner[28852]: Whitelist refresh time reached
Apr 25 22:39:05 smtp MailScanner[28852]: Starting up SQL Whitelist
Apr 25 22:39:05 smtp MailScanner[28852]: Read 92 whitelist entries
Apr 25 22:39:07 smtp MailScanner[28852]: Deleted 1 messages from processing-database
Apr 25 22:39:07 smtp MailScanner[28852]: Logging message 4413FA0056.A1FAB to SQL
Apr 25 22:39:07 smtp MailScanner[1132]: 4413FA0056.A1FAB: Logged to MailWatch SQL
With unrar-5.0.3-1.el6.rf.x86_64 maillog:
Apr 25 22:20:31 smtp MailScanner[28852]: New Batch: Scanning 1 messages, 1115916 bytes
Apr 25 22:20:31 smtp MailScanner[28852]: Virus and Content Scanning: Starting
Apr 25 22:20:32 smtp MailScanner[28852]: Spam Checks: Starting
Apr 25 22:20:36 smtp MailScanner[28852]: Requeue: A3A29A0056.A264A to D89DFA0057
Output from UNRAR v5:
unrar v -p- "sample(1) 3D.rar"
Archive: sample(1) 3D.rar
Details: RAR 4
 Attributes      Size    Packed Ratio   Date   Time   Checksum  Name
    ..A....    907264    812324  89%  24-04-16 18:38  80C3FDC5  sample 1.exe
               907264    812324  89%                            1
Hmm....I will check this and report back. Could be a bug in the new v5 parser.
Ramas
Post by Ramas »
Here I am again with unrar V5.
Today our customer received e-mail with RAR archive attachment.
Inside RAR archive executable .exe file.
Our mail policy - no executables in email, but Mailscanner (E.F.A.) that e-mail not blocked.
Output ftrom unrar with attached file in that e-mail:
 unrar v -p- 'offical PO and SC no 10_Pdf.rar'
UNRAR 5.21 freeware      Copyright (c) 1993-2015 Alexander Roshal
Archive: offical PO and SC no 10_Pdf.rar
Details: RAR 4
    ..A....   1314816    681138  51%  16-11-16 10:57  D7444A4F  offical PO and SC no 10_Pdf.exe
My suggestion for code changes in Mailscanner (... MailScanner/perl/MailScanner/Message.pm):
--- Message.pm.bak<---->2016-11-16 14:15:38.240733800 +0200
+++ Message.pm<>2016-11-16 15:24:01.695851594 +0200
@@ -3140,7 +3140,7 @@
         $Stuff = $what;
         $Stuff =~ s/^\s+|\s+$//g;
         chomp($Stuff);
-        my ($RAttrib,$RSize,$RPacked,$RRatio,$RDate,$RTime,$RCrc,$RName) = split /\s+/, $Stuff;
+        my ($RAttrib,$RSize,$RPacked,$RRatio,$RDate,$RTime,$RCrc,$RName) = split /\s+/, $Stuff, 8;
         $memb .= "$RName\n";
         $Stuff = '';
Correct Me If Im Wrong.
