I have setup a brand new Exchange and everything seems to be working if I take EFA out of the picture. i have the SMTP port in FW configured to go to EFA. I have tried sending email from Gmail and my work address but no luck.
>> #554 5.7.1 Service unavailable; Client host [xx.xx.xxx.] blocked using zen.spamhaus.org ##
Do I need to turn off the Exchange Spam controls? Does this not mean that I have to manage the whitelist/blacklist in two places?
Any instructions on how to Send via EFA using Exchange so we don't get blacklisted?
I implemented this in exchange, but it won't help since I cannot get any incoming emails showing up in EFA console or Exchange OWA
http://www.mcgearytech.com/efa-project- ... il-folder/
This was good but only took my so far, there is not much help for post install issues.
http://www.virtualtothecore.com/en/efa- ... appliance/
I would like to use EFA for my server, I think it is a good tool and wouldn't mind contributing but help is hard to find. Are there any detailed instructions for working with Exchange 2010 or Exchange 2013?
Receive failure and bounce back
Re: Receive failure and bounce back
This is your first problem. If you are listed in spamhaus, then you are blacklisted.11delphiwiz wrote:I have setup a brand new Exchange and everything seems to be working if I take EFA out of the picture. i have the SMTP port in FW configured to go to EFA. I have tried sending email from Gmail and my work address but no luck.
You can use EFA as a smart host for your Exchange server for outbound email. Add your exchange server to EFA as an outbound email relay using EFA-Configure ( 8 Mail Settings --> 1 Outbound Mail Relay). I also recommend you whitelist your internal Exchange server in the EFA MailWatch GUI (source=your mail server or ip, destination=default), unless you plan on spam filtering outbound mail.Do I need to turn off the Exchange Spam controls? Does this not mean that I have to manage the whitelist/blacklist in two places?
Have you added your email server to Transports in EFA-Configure? (8 Mail Settings --> 4 Transport Settings)I implemented this in exchange, but it won't help since I cannot get any incoming emails showing up in EFA console or Exchange OWA
Not yet, but I would be happy to write an Exchange Howto, if you'd like, for the wiki. I will have to spin of an Exchange and take some screenshots.I would like to use EFA for my server, I think it is a good tool and wouldn't mind contributing but help is hard to find. Are there any detailed instructions for working with Exchange 2010 or Exchange 2013?
https://efa-project.org/wiki/Main_Page
11delphiwiz
Thanks a lot for your help.
I checked in Spamhaus and my ip and domain are not blocked. MxTools also does not have anything block.
I can look into the other options you suggest soon after I have the Exchange working back again but right now even after removing EFA from the picture, I cannot send/receive emails. I may have to reinstall.
Do you have any posts you can point me to for post-deployment steps for an Exchange 2013 server. I don't mind taking screen shots and documenting for your Wiki.
thanks,
-Dave
thanks,
-Dave
What about your employer's domain....
