Post
by shawniverson »
Starting a thread on the Logjam Vulnerability.
I am currently researching and will post results and how-to here.
Post
by shawniverson »
Apache already has DH 2048bit and export ciphers disabled. No action needed here. Apache is not vulnerable in EFA to logjam
Postfix is vulnerable.
To fix weak DH key:
Generate a 2048bit Diffie-Hellman key
sudo openssl dhparam -out /etc/postfix/ssl/dhparam.pem 2048
Add the DH key to postfix:
sudo postconf -e "smtpd_tls_dh1024_param_file = /etc/postfix/ssl/dhparam.pem"
More info located here:
http://postfix.1071664.n5.nabble.com/Di ... 63096.html
To disable export ciphers:
sudo postconf -e "smtpd_tls_ciphers = low"
