Change Listening SMTP port???
wolfegang76
Post by wolfegang76 »
Hello all,
I too am a bit new to this EFA; grabbed the Virtual Appliance which is really slick by the way. Good stuff!
Version: Virtual Appliance 3.0.0.7... VMware
Everything is configured fine, BUT...
I am forced to use an alternate SMTP port which is coming inbound to my SMTP gateway/EFA... (ISP blocks 25 :(( )
The port I have been using as my Exchange connector is 26026...
How, or more importantly, WHERE do I go within the EFA (what config file(s) do I need to edit to change which port it is listening on for SMTP traffic. I have searched hi and low on this board before registering. I see alot of posts referencing the transport, but I want to alter the port that this EFA listens on for SMTP traffic..
I can telnet to :25 all day long and connect just fine, however, that won't work for me. I need it to listen on 26026.
Pretty simple really...
Any help would be GREATLY appreciated!!!!!!!
Cheers,
--wolfegang76--
wolfegang76
Re: Change Listening SMTP port???
Replying to my own post here:
But I found this:
To change the smtp port no. in postfix,edit the master.cf file and change the given below value
vi /etc/postfix/master.cf
smtp inet n – n – – smtpd
change smtp word to your desired port no. Here I am changing it to 9267
9267 inet n – n – – smtpd
Now restart the postfix
/etc/init.d/postfix restart
Check the port no. status with netstat command
[root@localhost postfix]# netstat -tanp|grep 9267
tcp 0 0 0.0.0.0:9267 0.0.0.0:* LISTEN 9788/master
I am assuming that this is not the only place to set the new port number for SMTP....
Again, I'm on stand by and any help will be greatly appreciated!
--wolfegang
That looks correct.
I'll add a feature request to allow port changes in the future.
wolfegang76
Awesome, thank you so much!
wolfegang76
So, YES, this DOES THE TRICK!
Additionally, one will need to also edit firewall settings on the EFA appliance as well.
Then, I simply made a few changes on my sonicwall NSA 240 and BOOM!
Works like a champ!
To test my spam filter, I inserted this: XJS*C4JDBQADN1.NSBN3*2IDNEN*GTUBE-STANDARD-ANTI-UBE-TEST-EMAIL*C.34X
into the body of the email.
We are golden!
A big thank you to shawniversion for help with this! The virtual appliance really makes the implementation of this system SOOO much easier!
Good stuff. It is running just great on vSphere 6.0.
=wolfegang
:dance: :dance: :dance:
