message marked as spam gives a razor error
Re: message marked as spam gives a razor error
double checking....guessing my the number of hits we are getting on this topic this bug is most definitely present....
Can anyone else confirm they are still encountering this exact error? I have applied the info for the fix and it is still giving me that error.
I am tracking this as well. If you are experiencing this issue still please provide feedback
yes.. took a bit of time to register (greylisting ).. anyway, in a default version 3.0.0.6 updated with the latest linux patches I've encountered the same issue, manually ran razor-admin - create and -register as the error pointed me in that direction, before having a look at this forum and changing the file ownership. Changing the file ownership (the 4 steps mentioned before) was the only way to fix it.
it's running on KVM on a linux x86_64 machine, latest updates, could be that yum's upgrade scripts changed the ownership of the files after release ?
I am going through the version history on git, could have sworn this was applied, but I just built one myself and it is not there....
Ok, found the issue....looks like some lines make reference to pyzor when they should reference razor.
Opening new issue.
Opening new issue.
3.0.0.7, build from the centos netinstall
selecting the SA Learn option of "As Spam+Report" results in the same error
The following 3 commands fixed the problem
(the group ownership was postfix before I changed it to apache)
(sorry, I didn't save the line number, but it was different from Antiloops)warn: reporter: razor2 report failed: No such file or directory report requires authentication at /usr/local/share/perl5/Mail/SpamAssassin/Plugin/Razor2.pm
sudo chown -R postfix:apache /var/spool/postfix/.razor
sudo chmod ug+rwx /var/spool/postfix/.razor
sudo chmod ug+rw /var/spool/postfix/.razor/*
Just for reference i also had the error:
The above Chown/chmod's fixed that issue for me. However i then got the problem "Use of uninitialized value $hasStructureInfo in numeric" which appears to be a known 3.0.0.7 bug.
Andy
Andy
I use EFA 3.0.0.8, I've tried :
But I've always this message :
Have you another idea to solve this problem please ?
Best regards.
Charles
sudo ln -s /var/spool/postfix/.razor /var/www/.razor
SpamAssassin: Dec 2 12:09:51.221 [4799] warn: reporter: razor2 report failed: No such file or directory report requires authentication at /usr/local/share/perl5/Mail/SpamAssassin/Plugin/Razor2.pm line 177. at /usr/local/share/perl5/Mail/SpamAssassin/Plugin/Razor2.pm line 330., Dec 2 12:10:09.599 [4799] warn: reporter: SpamCop report to vmx.spamcop.net failed: Net::SMTP error, 1 message(s) examined.
Best regards.
Charles
After registration and configuration
I've this message :
Spamcop sending it's OK but i've always this message ...
I've this message :
SpamAssassin: Dec 2 14:28:01.186 [2009] warn: reporter: razor2 report failed: No such file or directory report requires authentication at /usr/local/share/perl5/Mail/SpamAssassin/Plugin/Razor2.pm line 177. at /usr/local/share/perl5/Mail/SpamAssassin/Plugin/Razor2.pm line 330., 1 message(s) examined.
I'm sorry
After registration and configuration, I've execute again :
And it's OK for me.
Ran into this with 3.0.0.8 - downloaded as the Hyper-V VM.
Posted details here: viewtopic.php?t=1473
Hopefully these steps may help track-down why this happens for some people?
