EFA and Exchange
marquay
EFA and Exchange
Post by marquay »
My head hurts
I have installed a few times here, and set things up accordingly, perhaps it is my lack of linux familiarity. I managed to get AD/LDAP sync to work.
I simply cannot for the life of me figure out where to setup to allow my Exchange server to relay through the EFA server. I did the shell, and would like to see where in Webmin to do this as well. I can see in the logs where it shows my Exchange server creating the anonymous connection using TLS to EFA, then i get the notice that it does not have permission. Within webmin, where on earth is that setting?
I apologize for posting this, as i have read a few others on here and just can not seem to get it.
Any help would be amazing.
Thank you
Re: EFA and Exchange
Check out EFA-Configure
8) Mail Settings --> 1) Outbound mail relay
Put your exchange server addy in here :D
marquay
Post by marquay »
I have checked that several times, has been in there since beginning.
Try the ip too and make sure it resolves from the EFA.
marquay
Post by marquay »
OK, so DNS does resolve, however i changed it to the IP address and it is getting better results. Messages are going out now, yet seem to time out when connecting to other mail servers.
I have a feeling that is an issue on my end, and I am looking into it.
THank you
marquay
Post by marquay »
Soooooo
I can see the mails coming in....and this is in the log..
warning: dict_ldap_lookup: Search error 9: Partial results and referral received.....Temporary lookup failure.
It seems as if it is getting the LDAP and seeing that I am a valid recipient, yet won't deliver.
marquay
Post by marquay »
Sooo, i found this in there....
E30146005F: to=<postmaster@cmedics-llc.com>, orig_to=<postmaster>, relay=webmail.cmedics-llc.com[192.168.150.12]:25, delay=5, delays=0/0/0.02/5, dsn=5.7.1, status=bounced (host webmail.cmedics-llc.com[192.168.150.12] said: 530 5.7.1 Client was not authenticated (in reply to MAIL FROM command))
Which client was not authenticated here? The EFA to Exchange? The outside email server?
I think you may have more than one thing happening
1) Your LDAP is throwing a temporary lookup failure, so your lookups are incomplete
2) Your Exchange is requiring authentication for the relay
