run quarantine report for 1 user
Can I run the report for a certain user only?
Re: run quarantine report for 1 user
No, but that would be easy to implement.
The /usr/local/bin/mailwatch/tools/Cron_jobs/quarantine_report.php script would need modified to accept a single user...
Yes. If you create a user with the username username@domainname.com and select that you want to generate reports, that will generate a report just for that email address.
colin wrote:Yes. If you create a user with the username username@domainname.com and select that you want to generate reports, that will generate a report just for that email address.
I'm stuck in the command line world....
- Socal_Steve
It's the best place to be! always makes me laughshawniverson wrote: I'm stuck in the command line world....
I've got an T-shirt with that image on it
(thingeek)
