Allow extensions picked up as bad content
mikemachin
We have a number of files that we need to send out to customers that are being blocked on EFA that we believe previously went through on ESVA. is there an allowed list to add file extensions to so that these get marked as clean?
Re: Allow extensions picked up as bad content
Can you whitelist your internal mail server?
To: default
To: default
mikemachin
Would this allow everything out?
If so then this is something the security bods will need to ponder over but I see this as a possible fix.
In summary all we want to do is allow files of extension .prg out
Yes, you can also edit /etc/MailScanner/filename.rules.conf
After editing, restart MailScanner
